Sound deadening
Old 05-14-2007, 09:55 PM
kertoncol's Avatar
Sound deadening
Does anyone have a picture or description of how far up behind the rear bench they put their material? I'm just not sure if I should go up over the ledge directly behind the bench seat.
Thanks.
Old 05-15-2007, 07:45 AM
Pooter's Avatar
I went all the way up the back of the cab to the window, under the whole back seat area, and underseat storage. Also inside all the doors, and some on the inside of the door frame, I havent gotten to the front floor or roof yet, but I will soon with me putting the stacks on this weekend...
Old 05-15-2007, 11:41 AM
WUnderwood's Avatar
yeah, I went to the bottom ledge of the rear window. if you look real hard, you can see the Dynamat
Old 05-15-2007, 01:08 PM
kertoncol's Avatar
Thanks. I've driven around w/o the seats in and wow, is it loud when the vents open. I thought about closing them but someone here said not to unless you liked feeling the pressure increase in your ears.
Are you happy with the results?
Old 05-15-2007, 01:21 PM
Pooter's Avatar
Easy fix for the vents....
Get some foam padding for seat cusions at a fabric store, cut a square to go over the vent and tap them in place or use sound deadener to hold them in place... I used 1" thick foam, had some lying around from when I was going to add some to some old seats...
Sorta like a filter for the dirt that usually comes thru there as well as cuts down on the sound some...
Overall its cut down the resonance inside the truck down quite a bit, im sure when I get around to pulling the front seats and headliner and doing the front floor/roof it will help a ton too, but overall much better than before.
Old 05-15-2007, 02:22 PM
kertoncol's Avatar
Good idea about the foam. I noticed a lot of dust after removing the seats. Did you put one layer on the back wall or multiple layers?
Old 05-15-2007, 03:21 PM
Pooter's Avatar
Yeah, I thought about it while I had the back seat out, how dirty it was back there and just thought id try the foam, havent had any more dirt back there.
I doubled up on the back of the cab, but not the floor, didnt have enough material. If I have some leftover when I do the roof/front floor I may go back and double up the back floor area...
On the doors I did double up behind where the speaker mounts, and also sort of by doing the outer skin of the door, and then another layer on the inner door structure. It helped reduce the road noise quite a bit.
BTW, I used RAAM mat, check out their website, pretty innexpensive and works really well. Google the sound deadener showdown and you can see a comparison of popular sound deadeners....
Old 05-15-2007, 09:37 PM
kertoncol's Avatar
Yep, I'm also using RaamMat. So far it's working great. Tonight I pulled off the seatbelt anchors and placed a layer inside the pillars. Not sure how much it will help but I figure any amount of mass in there can't hurt.
Old 05-16-2007, 09:07 PM
kertoncol's Avatar
I finished the back seat area. Next will be the doors and then the floor. I drove it tonight and I can tell a difference.
Old 05-17-2007, 07:29 AM
Peterbilt's Avatar
Gee, I had no idea the vents were so big! Nie job installing the mat.
Where did you get the RaaMat?
Pete
Old 05-17-2007, 09:47 PM
kertoncol's Avatar
Thanks. I bought the RAAMmat directly from www.raamaudio.com. Shipping was prompt and the product arrived in good condition.
Old 05-18-2007, 12:08 AM
Luvnacumns's Avatar
Ok don't beat me down but what do those vents go to??? I never noticed them in my 05 or my mega or are the coverd???? I wanna do this so I've been keep in tabs on this thread fellas...Keep up the good work... Someone needs to do a write-up
Old 05-18-2007, 12:41 AM
WUnderwood's Avatar
I took this from a post above:
when I did my sound insulation/deadener, I left them alone, because I think the engineers at the factory know what they are doing
Old 05-18-2007, 12:42 AM
WUnderwood's Avatar
I dont really know what he means by 'pressure in your ears', but it sounds painful
Old 05-18-2007, 07:32 AM
Peterbilt's Avatar
Do you ever drive down the interstate with your windows closed then open a window and feel your ears pop or the pressure change.
Pete
Quick Reply: Sound deadening
