Sometimes it runs then it wont !
Old 11-12-2010, 04:35 AM
Gmon's Avatar
Having trouble figuring out why my 1990 5.9 will run then die. Can drive it awhile shut it off then 5 min later it wont start . Changed lift pump ,the filter, Checked shut off soleniod . Looked for water. Got power to soleniod. Even changed power sourse to soleniod Can see feul at injectors when getting air out of lines. It runs fine after starting then acts like its outta feul . The tank is full ! Lots of power when running ! It also will pull start when it dies ! It's driving me nuts !
Old 11-12-2010, 12:39 PM
92smokin blacky's Avatar
Sounds like you are sucking air somewhere. Check all fuel lines and tighten all fittings
Old 11-12-2010, 05:07 PM
Gmon's Avatar
Thanks for responding ! Someone else told me the same thing !
Old 11-12-2010, 05:22 PM
Cummins Guru
BigIron70's Avatar
Location: Sunny Southern California Land of Fruits and Nuts
Make sure the connections on run solenoid at injection pump are tight. Check the wire for chafing or grounding on bracket.
Old 11-13-2010, 05:13 AM
Gmon's Avatar
Thanks ! I did run a new wire there to a different power source just in case of an a electrcal issue
Old 11-13-2010, 05:45 AM
KD93's Avatar
After it dies, have you confirmed you're getting fuel to the filter/pump? I'm wondering if there isn't some kind of blockage at the pickup tube... It's either that or as 92smokin blacky said, you're sucking air somewhere.
Old 11-13-2010, 07:58 AM
APD
APD's Avatar
Even with a good power source, the shut of solenoid can be sticky. I had this problem...it always ran fine, but randomly would not start after shut down.
The way to be sure is remove the plunger from the solenoid, and re-install the solenoid without it. You will have to shut down manually with the lever on the pump. The next time it doesn't start, remove the plunger, if it immediately starts up, you will know that was the problem.
Another option is to just replace the solenoid, they are cheap.
Old 11-13-2010, 02:52 PM
Gmon's Avatar
I did check the filter after it died , and it was full !! Thanks though. I think I solved it !! The problem seems to be when I turned the ignition on power was interupted to the soleniod. I ended up running it to a toggel switch.So far so good !!
stanbnv
07-05-2011 11:10 AM
banks twinram
07-06-2010 05:14 PM
Beast2B
12-08-2009 01:44 PM
mr300x11
10-11-2007 08:46 PM
Dave88LX
03-02-2007 04:23 PM
Quick Reply: Sometimes it runs then it wont !
