Smoke!!
Old 01-18-2010, 02:38 PM
petrecca8's Avatar
Smoke!!
So me and my girlfriend are on our way home from walmart when these two 2nd gen trucks come flying past me obviously i sped up to keep right wit them and then they smoked me out to the point where couldnt see. Now my question is how the EDIT do i get my 1st gen truck with my 5 inch turnout stacks to send out a crazy thick cloud of black smoke. im jealous of all the other cummins i see doing it. i know they all have chips but how do we do it????
Old 01-18-2010, 02:49 PM
B-North's Avatar
Turn up your pump, particularily the smoke screw. There are some good how-to's on here. Those guys might be running smoke switches but you can't do that with a 12v.
Old 01-18-2010, 03:00 PM
unixcowboy's Avatar
Sure you can...
Crank the power screw up 'til you start to get runaway, then back off 1/4 - 1/2 turn.
That'll get you smoke on demand.
Then install a valet switch to cut down on smoke when you're cruisin', flip the switch and mash the pedal - instant smoke...
Old 01-18-2010, 03:01 PM
petrecca8's Avatar
how exactly do i turn up my pump? cause money is tight and i don want to be messin anything up and replacing stuff ya know what i mean
Old 01-18-2010, 03:04 PM
petrecca8's Avatar
is there a sticky on the smoke screw? i been wanting to do a valet switch i just havent found the time to do it.
Old 01-18-2010, 03:15 PM
unixcowboy's Avatar
Check this :
http://dodgeram.org/tech/dsl/more_power/Power_ve.htm
I wouldn't suggest you get carried away with this until you get some gauges.
Boost and EGT especially since these mods can make both go very high in short order.
In the reading where it says to 'take the screw out and put it in a vise' I'd suggest going after the collar with a pair of needle nose pliers, new ones with clean teeth at the front. I worried mine for about 20 mins and it came off.
DO NOT TURN THE POWER SCREW RANDOMLY!!!
You could hit runaway and you'll be sorry.
There are stickies on avoiding runaway...
Old 01-18-2010, 03:58 PM
grouch's Avatar
I know lots of ways to make smoke. I worked on one car with a son of a.....er....little darling who annoyed me seriously. I slid a birthday candle into the exhaust manifold. That new engine smoked like a freight train until the candle ablated. You can always do like the military often does. Make a port to attach a small line and a pump to inject oil (diesel fuel) into the exhaust. The heat of the exhaust will vaporize it but not burn it completely.
Old 01-18-2010, 04:00 PM
jimbo486's Avatar
that's awesome!!
Old 01-18-2010, 04:43 PM
Check out the videos in the sticky, Instructional videos on how to turn up the pump.
Old 01-18-2010, 05:56 PM
14racing's Avatar
Get a more aggressive fuel pin or grind your own. That will make it smoke more.
Old 01-18-2010, 06:48 PM
stackx2's Avatar
you want it like this?
Old 01-18-2010, 06:52 PM
JustRamIt91's Avatar
very nice
Old 01-18-2010, 07:51 PM
B-North's Avatar
Do you have any better pics of your bumper? I want to build one similar to that for my 1stgen.
Old 01-19-2010, 12:19 AM
peobryant's Avatar
The easiest way to make a bunch of smoke, without spending a lot of money is a trashbag over the air filter. Simple, inexpensive, and effective.
Old 01-19-2010, 06:22 AM
rockfoot's Avatar
"The easiest way to make a bunch of smoke, without spending a lot of money is a trashbag over the air filter. Simple, inexpensive, and effective."
LOL
Quick Reply: Smoke!!
