smarty level 7 or 9 whats your egts? stock turbo
Old 02-15-2010, 10:15 AM
1985cucv's Avatar
i was wondering what your guys egts are on level 7 or 9 with the smarty on the stock turbo i want to see if mine are resonable
Old 02-15-2010, 01:43 PM
BigBore050's Avatar
I run SW9 WG-off TM-4 RP-2 IT-2 And i see no more than 1300-1400, unless I stand on it in 6th and i can hit 1600, but by that time im doing 100+
I was running the WG on and the EGTs were out of controll.
But I dont tow any load with that tune
Old 02-15-2010, 03:27 PM
JTaylor's Avatar
I'll peg 1500 Degrees as soon as I hit the 1/8 mile with a Smarty TNT on SW9, TM 4, TQ 3, RP Default, TST 3-0, Edge EZ on 5 at 45 psi on a HE351. On the street with the same settings I will rarely ever reach 1100 without breaking the law. Cruising on the Freeway at 70 mph usually nets me around 5 to 6 psi and egts around 650 to 750. It can be a little touchy at times; but due to my loose converter and Smaller Turbo I run relatively smoke free. At times when it is a little touchy, I'll back down to Smarty TNT on SW9 POD 45TM on 1 and TST on 1-0.
Old 02-15-2010, 04:10 PM
1985cucv's Avatar
good thats what i like to hear the 2003 and 04s register a little lower on the egt scale as well correct? i probably will start running sw9 rp1 timing 2 wastegate off, and tq on 1 or 2 we'll see
what do you guys recommend for torque managment with a built 48 re? thanks
and is the tnt a lot better?
Old 02-15-2010, 08:36 PM
BigBore050's Avatar
The 03/04 will run cooler because of the lack of the 3rd injection event.
If your trans is built turn it all the way up. I ran SW7 TM on 4 with the stock clutch and she held it... well held it until we dicided to do a 4x4 boosted(20psi) launch and she came apart
I have heard a few people haveing problems with TNT and single turbo setups surging, dont now if they have fixed it yet but im going to give it a try when I get my new turbo
Old 02-15-2010, 09:39 PM
1985cucv's Avatar
yeah after reading i figure ill run sw9 timing 2 rp default tq 2 and wastgate off
Old 02-16-2010, 06:21 PM
Neight's Avatar
I just loaded sw7 tq4 rp stock tm2 and wast gate stock that's on right? and my egts are to hot when I hit lock up I'm at 1500. Anyone got any ideas on what I should change on my settings?
Old 02-16-2010, 08:44 PM
BigBore050's Avatar
If you are only seeing 30ish pis I would turn your wastgate off and allow that stocker to build more boost and it sould cool things down quite a bit. But on the other hand I will make 42pis witch they say is no good for the turbo or your drive pressure, so now im spending more cash on a better one,
Once you turn it up you cant turn it back down
Old 02-17-2010, 07:49 AM
bullhauler05's Avatar
When i had smarty i would see up to 1600 at times
Old 02-17-2010, 02:14 PM
Offroad226's Avatar
Highest i've seen was 1400 degrees at the end of the 1/4 on SW 7 all default settings with the stock turbo and intercooler and 1350 degrees with the aftermarket intercooler.
Old 02-17-2010, 05:19 PM
MikeyB's Avatar
Mine has never gone over 1250 with levels 7 or 9 using the standard Revo program. TM1, Timing2, RP1, WG off. This is with the stock turbo.
MikeyB
Old 02-18-2010, 06:15 PM
Neight's Avatar
Does anyone know if I add timming will it help drop the egt's? I'm running tm2 if I bump it to 4 will that help?
Old 02-18-2010, 08:08 PM
SuperiorRam's Avatar
i think its the other way around IIRC its been over a year and a half since i messed with it HAHAHa
Old 02-18-2010, 09:30 PM
1985cucv's Avatar
no timing should keep it cooler actually if im thinking right thats they way it was on the older ones it just increases drive pressure
Old 02-19-2010, 09:10 AM
Ya timing should drop them egts
Quick Reply: smarty level 7 or 9 whats your egts? stock turbo
