Small Leak detected!!
Old Oct 11, 2005 | 03:20 PM
lowtherc's Avatar
Today i was checking the oil in my 05' when i noticed a bit of pinkish stuff around the passenger side of the head. There are several plugs along this side and all are surrounded by a bit of pink dried stuff.. at one time this may have been wet and or coolant... Dont know. Should i be worried or call my dealer for a checkup?
Another quick question I am seeing up to 34lbs of boost STOCK is this normal?
My Truck
05' CTD 600 series, 2500 Big Horn, 3.73's, Autometer gauges (Pyro, Boost, Trans) 12,000 miles and counting
Old Oct 11, 2005 | 03:32 PM
N.Johnson's Avatar
I had the same thing as many others. Use a 3/8 drive extension on a ratchet or torque wrench and tighten them up. The 1/2" pipe plugs are 40 lbs's torque and the one 3/8" is 20 lbs's. Worked for me........no problem.
MadFrog's Avatar
34 lbs is normal. Mine would do 34 lbs peak and settle down at 32lbs.
CruisingRam
Jan 19, 2012 04:45 PM
jthorpe
23
Jul 4, 2009 01:22 AM
hector44
Feb 21, 2008 05:00 PM
