Small electric pump that saved my rear
Old 07-17-2011, 08:34 PM
oly_fab's Avatar
Took our yearly trip down to cali to run the rubicon trail. On the way down (1500 mile round trip) I noticed the truck loosing power. I run veg/bio and have a fram G2, racor 500 and a stock filter. The power loss is normally the fram clogging. I carry plenty of spares and we were close to stopping for the night so I just switched it out in the morning.
We hit the freeway in the morning and no power at all. We stopped and I could see alot of air in the fuel and had thought a line had gone bad. Limped it to the next exit and started trying to figure where the leak was. I have rubber lines from the LP that feeds my filters, I pulled the line rite after the LP and there was almost no flow. At WOT there was none.
So I'm thinking well crap bad LP, funny I know I just changed it about a year and a half ago. Lucky there was a orileys a block away. They couldnt get a LP till monday and it was saturday. So I asked if they had a 12v that had about 7psi output. Guy says well we have a 12v diesel that runs about that. Sure enough they had a 12v 4-7psi diesel pump...and it was $20 less than a new LP.
I plumed and wired it in and it solved the issue. The truck ran fine and didnt notice any diffrence. I'm buying another one to keep in the other truck, heres the pump http://www.jcwhitney.com/micro-elect.../p2031585.jcwx
Hope this saves someone elses butt.
Stu
Old 07-17-2011, 10:29 PM
BearKiller's Avatar
A smart man keeps an electric-pump installed in a bypass line, such that all it takes is the flip of a switch to bring it into action.
He also has at least one fuel-pressure gauge just ahead of the injector-pump.
Ideal is to have a gauge on the outlet of each successive filter AFTER the lift-pump, thus you can pinpoint just where the pressure stopped.
I do not trust any electric pump as the main lift-pump, but they do have there advantages, such as pre-priming the fuel system and purging any air.
I have a valved quik-couple on mine such that I can couple on a hose and pump fuel from any of my three tanks into any receptacle, be it a Dixie-cup or a Tiger tank.
Old 07-17-2011, 11:25 PM
Marty Z's Avatar
So how was the Rubicon.Dam I miss that trail.Use to live there.
Old 07-18-2011, 12:24 AM
Received 1,332 Likes on 862 Posts
Darn good info. Thank you for posting up your story, and the related parts.
Old 07-18-2011, 01:09 AM
oly_fab's Avatar
Bearkiller yep theres a pressure gauge, doh just didnt have time to wire it.
Marty Z it was killer as always this is our 4th year goin down. Love that area. They are filling ALOT of the trail with gravel... it wont be long and you'll see the ricer crowd in there.
Thrashingcows ya I hope it helps someone out, be a good thing to carry on long trips.
Stu
Old 07-18-2011, 01:59 AM
dieselluvr's Avatar
That's the same pump I'm using for my WVO system! So far so good and it's very quiet.
Old 07-18-2011, 11:25 AM
oly_fab's Avatar
It doesnt seem to mind my 50/50 blend of wvo/diesel. I'll have to get the pressure gauge finished I really want to know the pressure on it.
Stu
CruisingRam
01-19-2012 04:45 PM
Cummins Freak
07-01-2007 05:20 AM
NJMurvin
30
10-18-2004 05:53 PM
popeye
03-07-2003 08:14 AM
Battering Ram
10-29-2002 08:40 PM
Quick Reply: Small electric pump that saved my rear
