sitting for a month at a time
Old Dec 25, 2006 | 11:35 PM
Timmer's Avatar
i work on the river, and my truck will be sitting for 28 days at a time. and since i get back on the boat on the 3rd, this truck will be sitting out side, in the dead of winter. is there any thing i should do/be worryed about? think the stock batterys are strong enough to fire it after sitting in the cold for 4 weeks with out being pluged in?
Old Dec 26, 2006 | 08:19 AM
Lary Ellis (Top)'s Avatar
Admin Team Leader
I do mine like that all the time, it works just fine. I did have to replace both batteries recently, but it was time for them to go as they were around 5 years old.
I have a 12 volt solar cell that lays on the dash and trickle charges the batteries to keep them fully charged. It just plugs into the cig lighter, works pretty well for storage.
Old Dec 26, 2006 | 08:25 AM
rustbucket's Avatar
Thumbs up
If your batteries are good you should have no problem. My farm equipment can set for months,and I very seldom have any trouble geting them to start.
Old Dec 26, 2006 | 10:40 AM
OOPS's Avatar
I have a question about the solar panel. How can it charge your battery if you plug it into the cig. lighter? When you shut the key off the lighter does not work. I have thought about getting one for the rock crawler because it sits for a month or two during the winter and I disconnect the batteries so they do not go dead. I run dual Odyssey batteries, which are very expensive, and I want to keep them charged up.
Old Dec 26, 2006 | 11:02 AM
butchb's Avatar
I think the actual Cigar lighter stays on with the key off, the power outlet goes off with the key. At least on my 2006.
Old Dec 26, 2006 | 11:14 AM
Admin Team Leader
This depends on the year model of course as they seem to change from year to year. Obviously the solar charger has to be hooked up to a hot plug or it will not work.
On my camper there was a diode inline with the power outlet, it would not charge the battery using that outlet. I had to hardwire it direct to the battery in order for it to work properly.
Old Dec 26, 2006 | 04:51 PM
DBLR's Avatar
If the outside temps will be at or below 10 above zero then switch to 5w40 synthetic oil as this will aid in easier start up in the cold weather. FYI, 5w40 synthetic oil is approved for use in your 2006 and use it in mine. If you want to be sure just look in your owners manual on page 373 and on 374 is the chart with 5w40 listed.
Black SunShine 04
Jan 26, 2011 03:11 PM
dog rocket
Oct 28, 2007 11:51 PM
1qckdodge
Jan 10, 2007 08:50 AM
Buckshotmckee
Mar 16, 2006 06:53 PM
