shudder???
Old 07-15-2007, 11:12 PM
gullydog's Avatar
shudder???
shudder on take off but just had new u joint and rear end checked out possible brakes sticking???? need help very hard to locate
Old 07-15-2007, 11:47 PM
Redline Ram's Avatar
check the ujoint by the carrier bearing or transfer case they will sieze up and shake the whole truck at low speeds.
Old 07-15-2007, 11:59 PM
jaredb900rr's Avatar
Check all u-joints connected to the driveshaft. I had serious shudder on takeoff as well as a little clunk when putting it in gear. It ended up being the rear u-joint, totally blown. Then, about two months later, the shudder started again, but this time it wouldn't start shuddering til I hit 2nd gear and then it was really bad at about 60-65, started to go away around 70-75. This time it ended up being the middle u-joint, totally blown. I'm waiting for the one by the carrier bearing to go, but not looking forward to changing that one out!
Jared
Old 07-17-2007, 12:26 AM
gullydog's Avatar
dont think i have a carrier bearing???
Old 07-17-2007, 09:29 AM
dodgezilla04's Avatar
if yours is a long bed quad cab, you've got 3 ujoints and a carrier bearing. the center bearing may not be loose. drive it for a few miles, and then check its temperature with your hand. it'll be hot. It is seizing up.
Old 07-17-2007, 09:37 PM
gullydog's Avatar
i have a short box
Old 07-18-2007, 09:20 AM
TurboTed's Avatar
Try adding the friction modifier to the rear dif.
Old 07-18-2007, 02:35 PM
gullydog's Avatar
did that added 2 bottles ?????maybe rear diff is gone only 60km on truck??
Rafter B
04-13-2008 09:40 AM
danbaldy
26
04-05-2003 02:40 PM
joel
01-07-2003 10:18 AM
heavyhauler2
33
12-26-2002 07:41 PM
bigbaddiesel
11-30-2002 01:03 PM
Quick Reply: shudder???
