Shop for O rings, Calgary AB area
Old 03-30-2009, 11:25 AM
dvst8r's Avatar
I know there are several members in the Calgary, AB area on this board. So I was hoping that one of them could recommend a reputable shop for getting my 12V head o-ringed.
Old 03-30-2009, 01:39 PM
The Guru
Mike Holmen's Avatar
I asked D&W custom engine last year if they can cut orings but I never got them to do one. The 24v head that I dropped off was junk/scrap, so, I never got to findout. They seem like good guys to deal with. They are located in the north east at approximately center street and 34 ave area.
Old 03-30-2009, 01:40 PM
kennyblatz's Avatar
pop this over into the alberta chapter ABDTR you will get a better response. i did some calling around and it seemed like one of the bc companies was the best route by far cheaper and they have done lots of them. thats were NAD* is sending theres, funny NAD* quoted me triple the price. i believe it's mark at pdr or maybe peaks that you wanna talk to.
Old 03-30-2009, 01:50 PM
The Guru
D&W has someone local to cut the orings in. The fella lives in Balzac, almost near where I live. They can also port the head a lot cheaper than PDR.
I have an almost new cummins recon 24v head that has orings installed, available, if anybody needs one.
Old 03-30-2009, 02:01 PM
dvst8r's Avatar
Hmm, well maybe that isky cutter (cuts the block) is the way to go then... I am quite certain in my first gen chassis I have enough room to do it in frame.
Old 03-30-2009, 02:06 PM
dvst8r's Avatar
I will give them a shout, if there is someone local that has done them before I will go that route, if it is going to be a first time thing, I might as well be the one doing it.
Old 03-30-2009, 03:29 PM
Tate's Avatar
Currently, Kevin (Morkable) is looking to Track Engine in Edmonton to do his, depending on the price. I've never called D&W, but that could be another route. Peak doesn't do rings, but they did give me a number to a place in Kelowna to do it. I think PDR does it, but its all by hand, as they sold their machine to do it, so I've been told.
Old 03-30-2009, 04:45 PM
dvst8r's Avatar
PDR's Heads were done by Farrell, and as far as I know he is no longer there. He has been doing some contract work for Passenger, if I goto the effort of sending my head to BC, I will just send it to Passenger and have them machine off the intake while it's there. I will still call D&W and see about them, or this http://store.summitracing.com/partde...5&autoview=sku I will probably replace the copper with SS, or Inconel though.
Old 03-30-2009, 09:42 PM
1-5-3-6-2-4's Avatar
**subscribed**
I'll need my 12v head ported and ringed at somepoint to...............guy up in Rimby AB did my 24v head. I was happy with that result. but will look for other options when the time comes for this one.
Old 03-30-2009, 11:10 PM
Lil Dog's Avatar
Sure sounds like you know what you want for that block.. You and "firing Order" should have a brew...
Old 03-31-2009, 01:12 PM
dvst8r's Avatar
Originally Posted by 1-5-3-6-2-4
**subscribed**
Was it CT performance?
Old 03-31-2009, 07:11 PM
yup Aaron @ CT did my 24v head. I was happy with the job. but I'll shop around for the next one.
Old 03-31-2009, 07:28 PM
The Guru
Port the head prior to grinding the seats just in case you nick a seat. There has to be someone in Calgary, with all of the slow machine shops right now. Moores industrial can do the machining on the block, crank and head. They have a decking plate for the motor. I found someone who can do the custom crank balancing for the crank, I just need a truck to put it into and a little cash.
Old 03-31-2009, 07:56 PM
dvst8r's Avatar
Sounds like there might be enough guys around, that I can buy the isky one and rent it out at $50 a pop or so, and make it worth wile to everyone.
Old 03-31-2009, 09:53 PM
The Guru
dvst8r, I have a spare VE engine head available to experiment on and see how it works out. I probably could put together a ARP stud kit as well for that engine. I have two or three arp kits laying around my garage and old VE engine that some piston damage. Might even have a few big turbos just waiting there chance into get some action.
Quick Reply: Shop for O rings, Calgary AB area
