shock/level kit help
Old 11-16-2008, 05:25 PM
willTX's Avatar
ok guys i just got the hell bent steel 2.5" leveling kit, does anybody know what shocks are available for these. also what else is needed to avoid the death wobble and where can i get it ......thanks
Old 11-17-2008, 07:27 AM
Big Green11's Avatar
Bilstein 5100's, ordered mine from summit ~$73/ea
Old 11-17-2008, 08:20 AM
RowJ's Avatar
There are two different Bilsteins 5100 front shocks.
Some will tell you the standard length shocks work fine.... but I noticed a big difference when I went to the ones designed for 2-3" extra travel.
Standard length - BE 52549 - Yellow Shock
2" Longer Travel - BE 56681H5 - Nickle Plated
These #'s are from 2005, when I bgt them (before going to longer springs). Hopefully they are still correct.
"Rebadged"...... with what?
If you don't have a 'Streering Stabilizer', I strongly suggest one! HERE
RJ
Old 11-17-2008, 08:35 AM
gotslicks's Avatar
death wobble is a side effect of bad ball joints tie rod ends and negative caster.
buy some longer arms.
freight train
22
03-25-2013 04:46 PM
JJCAMARO1952000
07-04-2011 08:24 AM
kokalit
01-27-2010 10:11 AM
stumpjumper
08-21-2007 07:14 AM
Tree DR
02-01-2007 06:15 PM
Quick Reply: shock/level kit help
