seems like truck is running out of fuel at 70 and above?
Old 02-27-2010, 08:35 AM
1985cucv's Avatar
ok guys when im getting on my truck on the interstate it seems to hesitate a little bit and stumbles it really seems like i am running out of fuel. i have a fuel boss lift pump and the smarty turned on sw9 rp2 tm3 timing 1 wastegate off built trans with tripple disk when im cruising and put it down at about 70 it will not necessarily stumble but it just seems like it isnt pulling as hard. the rpms are about 2000 and from there up it just seems like the power isnt all there is this because im past the power band? im gonna adjust the smarty down to sw8 and see if maybe im getting tomuch timing and then to 7 and go from there any suggestions would be great thanks oh i have 3.73 gears as well
Old 02-27-2010, 09:32 AM
AH64ID's Avatar
What are you running for FP or RP? Boost? EGT's?
SW9 is a lot of program for a HE351.
TM3 isn't too much for timing, its not the most advanced.
Old 02-27-2010, 10:36 AM
1985cucv's Avatar
yeah i know its a lot for that im gonna turn it back down to sw 7 and try that i have my torque management on 3 not timing!
Old 02-27-2010, 10:52 AM
Administrator/Jarhead
madhat's Avatar
What is your FP and RP when this is happening?
Old 02-27-2010, 02:42 PM
1985cucv's Avatar
i dont have a rp gauge but fp is 17 all day long i turned it down to sw7 and the truck seems a lot stronger now really
Old 02-27-2010, 03:05 PM
AH64ID's Avatar
You were probably trying to push more fuel than your CP3 can handle.
Old 02-27-2010, 03:47 PM
nelrod's Avatar
^^^Prolly draining rail?
Old 02-27-2010, 06:44 PM
1985cucv's Avatar
yeah thats what i was wondering looks like ill have to upgrade my cp3 then!
Old 02-27-2010, 06:56 PM
AH64ID's Avatar
I would invest in a RP gauge if you want to run other than stock rail pressure.
jsflagstad
06-10-2007 06:43 AM
motrapper
02-07-2006 02:43 PM
coadman
03-09-2005 07:55 PM
98 2500
01-27-2005 09:40 AM
canucktrucks
04-18-2004 10:03 AM
Quick Reply: seems like truck is running out of fuel at 70 and above?
