Secondary Fuel Water Sep
Old 11-14-2003, 01:12 PM
induchman's Avatar
I've been reading about putting an additional fuel/water sep on diesels. Is it really necessary to run one ahead of the oem filter? If yes, where would you put it?
Old 11-14-2003, 07:18 PM
HammerMTB's Avatar
Where do you buy your fuel?
If you get your fuel at a station that is in regular use, and it's fuel supply is fresh, and has a filter before the pump, an additional pre-filter water separator is unnecessary. When I did a lot of marine service, I saw some nasty problems with water in the fuel. Some were old fuel, some were due to large tanks condensing water vapor in the fuel tank, and some were from "lightering" at sea. That's when a ship gets fuel from another ship. I know you're not doing that.
Point is, if you get fuel from a clean source, an additional filter isn't needed.
We did a test one time to see how much water a filter/separator could stop. It will filter/stop water that is coalesced in fuel, but if straight water is pumped thru the separator, it plugs and passes water. The point here being that if you get a load of fuel that is BADLY contaminated, likely no filter or filters will stop the damage.
So, long story, short input- I don't think they're needed.
Old 11-14-2003, 08:13 PM
Haulin_in_Dixie's Avatar
Re:Secondary Fuel Water Sep
The stock fuel filter is a 10 micron filter and is also a water seperator. You won't do much better.
Old 11-17-2003, 01:09 PM
induchman's Avatar
Thanks. Just putting the co-drivers mind to rest. I've had several boats, including my present tug, which has multiple fuel/water seps in place. Big Racors and a real pain, because of the diversity of fuels out there.
AH64ID
66
12-20-2012 08:09 AM
2171CTD
08-29-2010 07:15 PM
shortround
09-20-2003 08:04 AM
shortround
09-14-2003 07:21 AM
Quick Reply: Secondary Fuel Water Sep
