Seat cushion question
Old 06-30-2005, 08:52 AM
Pike's Avatar
On my 98 with leather seats, the driver's side is worn but not cracked, and the passenger's seat is perfect. Can I switch the 2 bottom cushions by just taking out the 4 bolts in the cushion, or are they not the same size and shape. I don't want to completely wear out my driver's seat. Thank you.
Old 06-30-2005, 04:43 PM
Txwelder's Avatar
Good idea hope someone chimes in, I would like to do the same.
Old 07-01-2005, 05:53 AM
sherod's Avatar
I switched on my 98. No problems, bolted right in. Both cushion bases have both sets of holes. (you'll see what I mean).
Think they were 10mm bolts.
Ed
Old 07-01-2005, 09:26 PM
Silverjay's Avatar
I did the same thing on my 2000. Fit right in, I think the bolts were self tapping and the drivers seat hit a different hole in the seat bracket. The bolts are 10mm, I had them off this evening to fix the power seat.
Old 07-09-2005, 12:59 PM
OTR PU's Avatar
Hey Silverjay, you can't just say this in passing, what was the problem with the power seat and how'd you fix it? I know about a hunnert hauler's with dead rear cushion adjuster motors. Fess up, are sitting on the solution? Pun intended.
Cheers,
Steve J
Old 07-11-2005, 11:55 AM
99 cummins's Avatar
Are you talking about pulling the whole seat at the floor mounts.
Old 07-13-2005, 12:02 AM
99 cummins's Avatar
Still looking for help on this one, about what exactly you change over and also what do you do with the trim and back adjustment ****.
DHT
09-19-2008 04:08 PM
pquevill
07-05-2008 08:40 PM
vzdude
10-30-2007 08:56 PM
jdeereboy
01-05-2006 10:50 PM
winner172
03-07-2004 05:33 PM
Quick Reply: Seat cushion question
