Seat belts?????
Old 10-08-2005, 11:10 AM
jsteezy1290's Avatar
Seat belts?????
i have the seat belts that are in the seat on the shoulder. but on both seats they wont release out of the seat.. anyone can help on this
Old 10-08-2005, 12:00 PM
torquefan's Avatar
On Quad Cab trucks, starting in 98, those belts have electric locks. Check your fuses, and make sure your door-ajar switches are working. Does the dome light come on when you open the door?
Old 10-08-2005, 01:23 PM
pretty sure it does.. what fuses are you talking about???
Old 10-08-2005, 03:55 PM
torquefan's Avatar
You better check them all, I don't remember which fuse runs the system. There is a fusebox in the dash, and one under the hood, on 2nd gen. trucks.
Old 10-08-2005, 04:56 PM
ednerin's Avatar
In my 98 1500 I found the seat belt lock device was attached to the underside of the middle seat with the rear seat cup holder. Not sure if that may have messed up on you but something else to check. Just my .02
Old 10-08-2005, 05:12 PM
not sure i disconneted all the wiring except the black box under middle seat cause i cant get to it.. fuses were good
Old 10-09-2005, 05:24 AM
jrs_dodge_diesel's Avatar
On the earlier quad cabs the seat belt could not be fitted with the normal pendulum style locking mechanism because if you leaned the seat back to far the belt would lock. So DC 'fixed' it with a electronic box which controls the belt locking. There was a trouble shooting guide for theis box posted several moths ago. I'll see if I can find it.
Old 10-09-2005, 06:29 AM
Ah ha, found it.
Click here . Post #3 by CTD2500.
Old 10-09-2005, 02:56 PM
i dont a cigar lighter in mine, als i unplugged all the wires under the seat, took out the seatbelt fuse and still nothing
Old 10-13-2005, 01:20 AM
big_ol_truck's Avatar
seatbelt genni
I had the same problem with my seat belts in my 99 quad cab. I would get into the seat and make sure that the connection to the bottom of the locking device is all the way in, mine came out somehow.
Old 10-18-2005, 08:51 PM
Geico266's Avatar
Did you guys get it fixed?
This happened to me when I removed a seat to fix it. I turned the seat upside down for repairs (my big butt broke the wires ) Anywho, the truck thinks you have rolled it over and it has the seat belts locked to protect the occupants. To fix it disconnect the batteries for an hour. There is another way to fix it with the cig lighter or something, but I don't remember the combo of events you need to do. Just disconnect the battery for an hour. It should reset to work properly.
hipsi
11-14-2007 12:36 AM
taildragger
12-01-2005 12:07 PM
coiler33
11-27-2005 07:48 PM
AggiePhil
02-08-2005 03:31 PM
ramlovingvet
03-30-2004 06:54 AM
Quick Reply: Seat belts?????
