RWAL controll valve
Old Apr 15, 2005 | 08:29 AM
dIlLiGaF's Avatar
Question RWAL controll valve
I need to replace my RWAL control valve. Can any one tell me if the brake bleeding procedure is the same as non abs brakes and do I only have to bleed the back brakes? One last question, has anyone used the speed bleeders that are available from russell and if so do they work as advetised?
Old Apr 15, 2005 | 12:37 PM
dIlLiGaF's Avatar
What, nobody here has bled their own brakes?
Old Apr 15, 2005 | 01:27 PM
infidel's Avatar
You're the very first person I've ever heard of who has had to replace a control valve. I would assume you will have to bleed both the the front and rears.
Old Apr 15, 2005 | 03:16 PM
dIlLiGaF's Avatar
Ya, unfortunetly some moisture got into the eletrical connection on the control valve and shorting it out taking the control module with it. I was able to pick a module from a wrecked 1500 but the valve is a dealer only item. Should use the speed bleeders or am I better off to invest in a presure bleed system?
Casket Man
May 11, 2006 06:24 PM
newtododge
Mar 25, 2006 08:15 AM
kcprecision
Jun 5, 2004 07:50 PM
lucey
Mar 7, 2004 10:59 PM
tomsauto
Dec 28, 2002 08:57 AM
