rusting floor pans
Old Jan 14, 2007 | 08:49 AM
91.5CTDBanks's Avatar
rusting floor pans
This past fall I noticed the carpet wet in the truck. So I started looking for areas for water to get in side and found both cowls leak, rear window and condensation from the a/c heat exchanger. So I pulled carpet and all the sound blanket and found a good bit of surface rust. Every one might want to check on this. I felt that my truck was in great shape and I should not worry. (Besides, nothing has ever been hauled in the bed.) I sanded, primered and put a can of bed coating on both floor pans. Turned out good, bought the Dupli-color brand and one can did both pans. Picts attached.
Attached Thumbnails rusting floor pans-floorsand.jpg   rusting floor pans-floordriv.jpg   rusting floor pans-floorpaint.jpg
Old Jan 14, 2007 | 09:10 AM
Ace's Avatar
Ace
Nice work!
Old Jan 14, 2007 | 09:48 AM
89dieselkong's Avatar
Happened to me, I had to cut out the floor plan and weld a new one in. Pain that it was, it was worth it
Old Jan 14, 2007 | 10:35 AM
DieselSmith's Avatar
yeah my entire driver side floor pan is completely cancerous, from the pedals to the seat. The other side is started to get some rust. Both of the spots include rust that extends into the rocker panels; more so on the drivers side.
Where is the best place to get replacement parts?
Old Jan 14, 2007 | 11:04 AM
Jim5870's Avatar
When I bought my truck new in 91, I knew carpeting and farm mud
don't get along. I pulled the carpet and stored it away, then I had the whole cab floor covered in spray on bedliner. easy to clean and no rust issues.
Old Jan 14, 2007 | 11:33 AM
Hemi Dart's Avatar
Talking Off topic............
91.5CTDBanks,
This Mopar has rusty floors too. In fact it's pretty rough.
http://www.worldofwheelz.web.aplus.n...y/DSC00028.jpg
Car:
http://cgi.ebay.com/ebaymotors/ws/eB...062&rd=1#Photo
Old Jan 14, 2007 | 01:52 PM
Carpet has no place in a truck. They should all have rubber floor mats.
Old Jan 14, 2007 | 02:06 PM
ofcmarc's Avatar
Originally Posted by Hemi Dart
91.5CTDBanks,
Car:
That's nothing, I had a '75 W-100 that the rusty floors were held together by the wet cardboard I never cleaned off the floor. Worked OK for me. My brother however borrowed the truck for a while and his gilfriend complained about the mess . He cleaned out the truck and took her for a ride. That went OK untill he hit a large puddle and the spray inside thew cab was unimaginable... So was the look on the girlfriends face
Old Jan 14, 2007 | 02:26 PM
broncobilly's Avatar
Good job on the floor repair! I hate to see what's under the carpet on my 93 My 70 Bronco was rusted pretty bad under the front carpet, and it was even an AZ rig
Old Jan 14, 2007 | 08:28 PM
Thanks guys. Yea, it is better to get ahold of it soon.
Old Jan 14, 2007 | 09:42 PM
woodrat's Avatar
I have wet carpet too, and i've started to worry about the potential for rust. the truck came from the dry side of the mountains so it hasn't been wet for all of it's life anyway.
But where did you find the water leaking in from? How did you fix the leak?
I like the bedliner idea the best..My 77 M880 had plain steel floor with rubber mats, very nice. Will it get much noisier if I skip the carpet altogether?
Old Jan 15, 2007 | 06:12 AM
Well, I have not fixed the leaks yet, just the rusting part. I really do not know how to fix the leaking part without pulling the fenders.
Old Jan 15, 2007 | 11:59 AM
woodrat's Avatar
Where is the leak? Did you leave the carpet out? I used to think the leak was around my door seals, but they just don't look that bad.
Old Jan 15, 2007 | 06:24 PM
Most of the water comes down the drivers side 'kick' panel close to where the park brake is. I figure it is the cowls that have cracked.
Old Jan 17, 2007 | 09:07 AM
Jim5870's Avatar
I had my floor sprayed with polyurethane when I bought it new,
16 years of farm mud with no problems. Just hose it out once in a while.
