Rough dissengaging cruise control.
Old Nov 5, 2006 | 01:37 PM
onemoretruck's Avatar
Please bring in your experimenting with your cruise control.Mine while working good at about every level seems to offers what I would call a "rough dissengaging phase". Lets say ,while cruising flat highway situations,if I would call for rather reducing speed or plainly getting out of cruise there was a fair amount of clunking noise accompaigning this ..nothing smooth there for sure. Now I must precise this is a 1994 5 speed manual transm. truck. The jerking was strong enough to make me feel like not sing it.If I woul demand for accelerating then everythig was OK and smooth.
While I understand there is a phenomenon of compression braking taking place I still don't think my clunking as normal..if so there is a bad design here.At only 63K miles I believe everything on the drivetrain to be thight..no play on the drive shafts to be felt and the truck feels rock solid .
When I would down shift manually ,from habit,I would play the throttle and then everything is smooth as butter..could it be the fuel delivery getting returned to zero too rapidly with a defective cruise and this would explain this?
thanks,Ron.
Old Nov 5, 2006 | 06:42 PM
infidel's Avatar
The cruise control has no components that can clunk. Even though you say you checked the u-joints that sure sounds like the problem. The problem is definitely in your drivetrain or loose mounts
Old Nov 5, 2006 | 06:49 PM
bnold's Avatar
Mine dissengauges roughly as well. I try to have my foot on the gas and kind of meet the cruise so it doesn't let off so hard
Old Nov 6, 2006 | 09:17 AM
tool's Avatar
Probably u-joints as Infidel said. Even though I could feel no slop in my joints I replaced the amm recently and it made a world of difference. Could also be your rear pinion has some slop and needs set up.
Make sure that you check for u-joint play in Neutral (with the truck secured from rolling!)
Old Nov 6, 2006 | 05:27 PM
Homestead's Avatar
Correct me if I'm wrong but wasn't there a thread about putting something in the cruise control vacuum line to make it engage and disengage smoother.
My cruise works fine but is a little abrupt when it disengages.
I think I remember the post having something to do with softening the way the cruise comes on and off.
Anyone remember this thread?
Jeff
Old Nov 6, 2006 | 05:30 PM
Kemble's Avatar
I always thought mine was rough on turning off due to the rear end having some play in it. I just match the speed with a little skinny pedal before turning off the cruise, makes it silky smooth then.
Old Nov 6, 2006 | 06:05 PM
Common's Avatar
Nothing wrong with your truck!
Just match the speed then let off smoothly...
As others have said...
Not a U-joint, or rear or something broken...
Its gear slop in 5th... nothing to worry about.
Firstgenfanatic
Nov 8, 2009 04:05 PM
Landini1
Mar 6, 2009 07:01 PM
trophystock
Jul 6, 2006 06:28 PM
Mexstan
Mar 31, 2003 02:37 PM
TexasDiesel
Dec 27, 2002 10:47 AM
