Rising temp with 1/2 throttle, also leaking coolant
Old Nov 14, 2008 | 10:10 PM
dnobles's Avatar
Lately my temp gauge starts to rise with 1/2 throttle, empty or loaded. Just pulled a load of cows (23200 lbs gross) ~260 miles on interstate & backroads. The truck did not run hot just spiked a temp(+200), temporarily by the in-dash gauge with ~1/2 throtle. Any good ideas?
Old Nov 15, 2008 | 12:34 AM
TexasCTD's Avatar
I'd say that was normal. Nothing to do. Mine will spike up a little over 200 for a few seconds not even towing...just getting on it some.
I'd say if you get up to 220-230+ sustained then you would have a cooling problem.
I think you are good.
Old Nov 15, 2008 | 12:36 AM
kw5.9's Avatar
I agree with TEXASCTD, i have gotten it over 200* just getting on the hwy and I cools back down pretty quick, and that was empty
Old Nov 15, 2008 | 01:30 AM
Jeff in TD's Avatar
What is your coolant leak? If it is dripping off the bellhousing, chances are it is the two hose clamps on the short section of hose by the turbo...
Igor
Jun 27, 2009 03:17 AM
Pull Dog
Nov 7, 2008 06:53 AM
jcg
Oct 15, 2008 09:51 PM
jaxworks
Oct 27, 2006 08:49 AM
