The right clutch?
Old Jun 5, 2008 | 07:57 PM
oilfield-trash's Avatar
The right clutch?
My dual disc clutch is going out AGAIN!! this one made it 70,000 miles. Clutch is slipping also.
SBC?
OFE - A little noise at idle? A lot of noise at idle?
ConOFE? Hard to back up with a 24,000 trailer up a grade?
Hyd upgrade?
Valair?
Help me make the choice. I pull heavy. I drive A BUNCH!! 8-10,000 miles per month. Would like a stock pedal feel. I will be pulling with 50hp injectors and the box off. But when the trailer gets dropped off
Old Jun 6, 2008 | 12:45 AM
Dieselnick's Avatar
Con OFE definitely. Valair definitely not. Haisley maybe.
Nick
Old Jun 6, 2008 | 07:33 AM
Fisherguy's Avatar
I'm wonering if going back to a single disk is the right move considering you burnt out a DD?
I'll be going to an OFE when the time comes, heard nothing but good things about them.
Old Jun 6, 2008 | 08:24 AM
rip 112's Avatar
I have an OFE and love it, I tow heavy sometimes but play around alot, and it does a very good job of holding. The FE is more grabby period, but it will hold more. What DD setup did you have? I know the SBC DD kits should last longer than 70,000 miles.
Old Jun 6, 2008 | 04:19 PM
0524VHO's Avatar
i just put a valair ceramic in my truck, and no complaints here.
Old Jun 6, 2008 | 05:04 PM
dodgezilla04's Avatar
you mean FE, is jerky for towing trailers. they hold well, but the driveability can suffer
the ofe is outstanding for trailer towing.
but, like mentioned above, if you killed a DD, you gotta figure out why before getting another one. i dont see enough mods to kill a DD, unless you bought a generic one, or driving style.
Old Jun 23, 2008 | 07:53 PM
Got the Con OFE installed today with the solid flywheel and hyd upgrade. Drove it home, about 260 miles and I love it. chatter is bearly noticeable. I was actually able to put my Edge on level 5 and the clutch not slip. Its the way to go.
Thanks Michael @ Hot Rod Diesel in Hitchcock TX.
Old Jun 23, 2008 | 08:28 PM
rip 112's Avatar
Glad everything turned out for you! Have fun with that new clutch!
Old Jun 24, 2008 | 12:20 AM
GlennRMK's Avatar
I had the OFE in the my 01. I had 30k on mine. No problems.
Old Jun 24, 2008 | 09:38 AM
South Bend Clutch's Avatar
Vendor - Former Vendor
I think whan he said DD he meant his Dual Mass flywheel is going out.
Peter
Old Jun 24, 2008 | 11:59 AM
gafirefighter's Avatar
i've got about 6k miles on my southbend dd 3250 and i have absolutely no complaints. it is a stiffer clutch but it isn't very grabby. i pull pretty heavy (around 20k w/ truck and trailer) at least once a week and i haven't had a problem so far. better have your wallet ready though
Derek Crowl
Aug 20, 2013 10:43 PM
hulmule
Mar 10, 2010 10:42 AM
jmccart
13
May 5, 2008 04:17 PM
00Dog
Sep 19, 2006 05:21 AM
Junk Yard Dog
Mar 15, 2004 10:47 PM
