Replacing stripped rear wheel studs on a 2004 2500 SRW
Old Jul 25, 2009 | 05:55 PM
dodge35000's Avatar
What is involved in replacing stripped rear wheel studs on a single rear wheel 2004 2500? Do the hub and rotor have to be removed?
Old Jul 25, 2009 | 06:49 PM
madhat's Avatar
Administrator/Jarhead
I'm on it... hang on...
Old Jul 25, 2009 | 06:54 PM
madhat's Avatar
PM sent. Not too much help. I've just beat studs out with a 5lb sledge, probably not the best way to go...
Old Jul 25, 2009 | 07:20 PM
rootercycles's Avatar
pound 'em out and replace with new ones. Simple as that.
Old Jul 25, 2009 | 07:43 PM
Mocho's Avatar
Do you guys happen to know if the fronts and rears are the same? Dealer wants like $28 for a stud, and NAPA can only get fronts, which are like $5....
Old Jul 25, 2009 | 08:59 PM
dodge35000's Avatar
To pull the studs on the front axle seems pretty easy. However, for the rear axle you have to remove the hub in order to pull the rotor off. That involves pulling the rear axle and the rear axle bearings. It just seems like it should not be that involved to just replace a wheel stud.
Old Jul 25, 2009 | 09:12 PM
madhat's Avatar
Well, removing the rear axle is not as hard as it seems... just unbolt it from the hub and go. You might need new gaskets, but other than that and some more fluid...
MikeRP
79
Nov 21, 2016 10:19 PM
rcts
Nov 21, 2009 11:29 AM
EverydayDiesel
Jun 27, 2007 07:07 PM
xxwildbillxx
Jun 15, 2007 01:37 PM
dragginlx
15
Mar 9, 2007 11:32 AM
