Removing Silencer Ring help
Old 12-01-2003, 10:51 AM
Hairy1's Avatar
Location: Adirondacks of New York and Daytona Beach FL.
Any help on this subject
Old 12-01-2003, 11:17 AM
matthopp's Avatar
Re:Removing Silencer Ring help
Try this thread https://www.dieseltruckresource.com/...4162#msg204162]
Old 12-01-2003, 11:18 AM
screwstrokin's Avatar
pull off front rubber intake that goes into the front of the turbo. loosen hoseclamps pull it clear
on the inside of the turbo you will see a expanson ring around the outer edge holding a metal plate with a whole in the middle, that is the silencer ring. just use 2 small screwdrivers to work that ring out of the grove and pull the ring out. hope this helps
Old 12-01-2003, 12:33 PM
Kimrey's Avatar
DIDO,
Kimrey
Old 12-01-2003, 06:49 PM
blackjack's Avatar
what screwstokin said I had mine off in about 10 min it's real simple. Once you get an end started just keep working it around. It is kinda like taking off any snapring if you have done that it is the same thing. then listen for the whistle the more air the better the whistle
PapaPerk
23
01-01-2005 07:33 AM
brandon507
07-17-2004 08:40 AM
jrs_dodge_diesel
17
12-12-2003 08:16 AM
tanderson2002us
10-15-2003 10:24 PM
Hoss
50
09-23-2003 06:20 PM
Quick Reply: Removing Silencer Ring help
