Recon Cab light Question
Old Dec 15, 2007 | 06:08 PM
haloman's Avatar
Question about the wiring. My 01' didnt come with cablights factory. I recieved the Recon SuperWhite Cab Lights for Christmas. It has little wires coming off of it. Do I need any additional Harnesses or anything? Or is it there already and I just wire them in? I know about drilling the holes and Ive got that covered.
TIA,
Daniel
Old Dec 15, 2007 | 06:13 PM
BBA's Avatar
BBA
not 100% sure but i think you will have to run wire up there but dont hold me to it.
Old Dec 15, 2007 | 06:26 PM
cmac's Avatar
i put cab lights on mine as it didn't come with them either. i took my corner light out and figured out which wire turned on the marker light and then pulled out the light switch and found the same wire (by the color code of the wire) and tapped into that then just ran one long wire up through the a-pillar and across the inside of the cab under the headliner.... and then tapped those short wires into the long one..... no problems yet!! hope this helps.
Old Dec 15, 2007 | 07:29 PM
torquefan's Avatar
I would personally tap the cablights into the trailer tow relay (if your truck has one.) just to keep the extra load off the headlamp switch. The park lamp circuit is already pretty heavily taxed. If you don't have your trailer taillamp circuit powered by a relay, you may want to consider adding one for the cab lights.
Old Dec 15, 2007 | 08:11 PM
haloman's Avatar
I am waiting on a call from a local body guy who has done several installs, to see what he says, but keep the ideas coming.
Old Dec 15, 2007 | 10:56 PM
GFB's Avatar
GFB
Did you get the LED set? I think all the new ones come with LEDs. I wouldn't worry about current draw with the LEDs. You can pretty much tap in anywhere on the parking light circuit.
Old Dec 15, 2007 | 11:49 PM
JonnyThrottle's Avatar
It should be the LED's, but i would also use the trailer one. Might as well save the parking lights from the strain. You never know
Old Dec 16, 2007 | 10:20 AM
BBA's Avatar
BBA
It will be the LED's.
Old Dec 16, 2007 | 04:41 PM
haloman's Avatar
They are LED. After talking to the Body man I am just going to use the parking light circuit ran up to the lights. I was going to put my big rig running lights on today but they didnt send the brackets.
Old Dec 16, 2007 | 07:52 PM
GFB's Avatar
GFB
If you're worried about straining the circuit then wire up a simple bosch relay. They only cost a couple bucks and that will ensure they draw power directly from the battery (or whatever power source you tap for them).
Old Dec 16, 2007 | 07:53 PM
Willy91's Avatar
I installed mine today, I just took the switch out and used a test light to find the wire, I believe it was orange and white on mine.
Old Dec 17, 2007 | 08:00 AM
haloman's Avatar
Thanks *****, I think the 98 and up have a different Switch. Can anyone confirm which wire I should be looking for?
Old Dec 21, 2007 | 09:32 AM
mr bill's Avatar
Haloman, are the cab lights installed yet and if so how do you like them? I am trying to deside on stock ones or Recons LED kit. I light the idea of LED better but was wondering about how bright thet are vs. the stock ones.
Old Dec 21, 2007 | 04:50 PM
haloman's Avatar
Not yet. My body guy is busy and hasnt got back to me yet.
Old Dec 30, 2007 | 09:56 PM
sledcrusher02's Avatar
cab lights
just go to the ******* and buy the oem harness that plugs into the back of the fuse box and routes up the pillar and across the roof. that what i did.
