Rail pressure on the latest Smarty 4.4 no SL
Old 10-16-2007, 07:10 AM
tcr
tcr's Avatar
I'm really only concerned about 03-04 trucks at idle, but everyone can chime in. I'm seeing stock rail pressures at idle, 5300-5400psi, some are seeing much more at idle. As far as I can tell this latest beta is a little different and it ROCKS! Seems like better throttle response w/o touchiness, also seems to pull harder than ever. The dyno will tell.
Old 10-16-2007, 08:43 AM
XtremeFlow's Avatar
My 06 idles at 8200-8400 on sw-9 which is up from 6600-6800 it does stock. Yours sounds about normal to me the 03-04 seem to idle at lower psi.
Old 10-16-2007, 11:56 AM
cquestad's Avatar
Normal...for 03-04.
Old 10-16-2007, 01:19 PM
tcr
tcr's Avatar
So even w/ the 4.4, the 03-04 trucks are going to only see 5300-5400psi at idle? Why are the 04.5s and newer seeing much higher rail pressure(8000-9000psi) at idle?
Old 10-16-2007, 03:04 PM
Heston_ram3500's Avatar
mines been idling about 8000, even up to almost 10. seems way to high.
Old 10-16-2007, 03:56 PM
tcr
tcr's Avatar
That's normal on the 325/600,610 engines, I was worried about mine being too low.
5.9Excursion
03-13-2008 10:56 AM
wreedCTD
31
10-24-2007 06:28 PM
LooseBoltsRob
12-13-2006 12:25 PM
Quick Reply: Rail pressure on the latest Smarty 4.4 no SL
