Rail Gauge
Old Nov 5, 2006 | 04:24 PM
Luken's Avatar
Rail Gauge
The optix rail gauge is AWESOME!
It was very interesting to see what was going on.
Crazy Larry adds NO pressure.... I had always heard that it does and assumed it did. I have talked to 2 other guys running the Crazy Larry tune and they said theres didn't either.
The mp-8 adds ALOT if it's turned up. I had no idea it added as much as it does. Cruising at 15,000psi you can turn it to 75% and it adds 8,000psi.
Old Nov 5, 2006 | 04:33 PM
wap's Avatar
wap
Nice little tool to have aint it.
Old Nov 5, 2006 | 05:45 PM
emfc_22's Avatar
were do you get a rail gage?
Old Nov 5, 2006 | 11:13 PM
pooperscooper's Avatar
id like to know where to get one as well....
Old Nov 6, 2006 | 12:56 AM
fjbiker86's Avatar
i just found the gauge today in genos garage..luken thanks 4 the great info. I was gonna steer away from crazy larry mainly because of the high rail pressure and go smarty. but now w/ this new info im thinken crazy larry again
Old Nov 6, 2006 | 06:34 AM
wap's Avatar
wap
dieselspecialtiesllc.com
Old Nov 6, 2006 | 08:01 AM
cmnspwr's Avatar
Diesel Power Products is having a TDR sale on them through the end of November.
Old Nov 6, 2006 | 08:37 AM
RAT_03's Avatar
DTR's "Secret Agent"
How hard is it to hook one of them up?
Old Nov 6, 2006 | 08:52 AM
neverenough's Avatar
What about on the regular old extreme setting have you tried it with the gauge?? I unfortunately cant run CL so i have to settle.
Old Nov 6, 2006 | 09:05 AM
Luken's Avatar
I don't see any pressure at all added with the bully dog on any setting. I have confirmed this with two other guys who run a rail gauge. Possibly it might add pressure but at the same time it pulls the rail pressure down so it evens out. Instead of draining the rail like the tst does.
It is SIMPLE to hook up. Plug the harness into the rail, hook up a grey wire to a ground, red to 12v, white to dimmer. Done! It comes with everything you need plus some extra wiring parts. Great kit!
Old Nov 6, 2006 | 09:17 AM
RAT_03's Avatar
so really if your running the BDDL-CL and the TST, you need the MP 8 right?
Old Nov 6, 2006 | 09:37 AM
Luken's Avatar
I can't run the tst/bddl anymore because my truck has been screwed up since I loaded/unloaded the Smarty on my truck.
I can't even run the tst by itself anymore....
On the triple stack the mp-8 is the only thing keeping your rail from completely draining without a modified cp3.
Old Nov 6, 2006 | 10:52 AM
lmills's Avatar
none of the bullydog downloads do pressure....they do however do a nice job of bringing the pressure up faster.
Old Nov 6, 2006 | 11:02 AM
badcompany's Avatar
I was thinking about getting one of these but was told it is a 2” gauge . Will this fit in an autometer 2 1/16 dual steering wheel mount? Thinks for the help.
Old Nov 6, 2006 | 11:06 AM
Luken's Avatar
I have mine in an autometer sterring wheel mount...
