Question for SuperDuty re: CP3S AGAIN!!
Old Jan 11, 2006 | 07:59 AM
sawboywv1's Avatar
OK it's been 2 days now and everything is bone dry. So my question is.....
1. was what I was getting from install of new pump? maybe where the pump
mates to the housing some fuel was left behind during install that made
its way out?
2. do you think this CP3S is OK?
3. if so, I guess I should bite the bullet and install some form of aux. pump
i.e. FASS? or your setup?
thanks,
all your info on these problems has been very helpfull!!!!
Old Jan 11, 2006 | 09:18 AM
DmaxEter's Avatar
They just replaced mine last friday and didnt wash the fuel off that had leaked out while they were changing it. It had more fuel on it when I got it back then when it went in. I washed the fuel off and it looks good now. They also left two of the mounting nuts off. Had to take it back and get those installed
Old Jan 11, 2006 | 09:38 AM
Superduty's Avatar
You appear to be under warranty, so drive it and don't worry about it.
I'd get the lift pump tested to be sure that works OK.
I wouldn't use the box for a while.
I'd be very careful about using that box until this gets resolved. Being you are on your 3rd CP3, it wouldn't take much for someone to void your warranty and the next CP3 is on your dime.
You know my position on the aftermarket fuel pump.
Old Jan 11, 2006 | 09:43 AM
sawboywv1's Avatar
No Dout!!!
Old Jan 11, 2006 | 09:48 AM
Superduty's Avatar
I think if I were you I would have a talk with my dealer about the lift pump issue.
He might approve of changing the pump to something aftermarket to get rid of this problem. He might also get serious about testing your lift pump. Ask him if he has a way to test it with some backpressure, like 10 PSI. That might find an intermittent pump.
Old Jan 11, 2006 | 11:08 AM
sawboywv1's Avatar
SD, is there possibly a cavity between the mounting faces where the fuel could have layed,that finally made its way through when the motor was hot the other day towing? Temp gauge did run 200 so I know its the hottest its gotten since the pump was replaced.
Old Jan 11, 2006 | 11:29 AM
Superduty's Avatar
Doubtful.
I think either the lift pump or the box is involved in these failures. I'd love to know which one.
If you drive it as it is without the box and it fails and the lift pump proves bad, then we know the lift pump caused it. Easy to fix.
If you get the lift pump diagnosed and it is bad and you get it replaced and you never get a leak again, we know it is probably the lift pump. Easy to fix.
If you get the lift pump diagnosed and it is good. And you put a pressure gauge on and it shows OK pressure to the CP3 at WOT. And you drive it for a while without the box and it is OK. And then you turn on the box and it fails. You know it is the box. Easy to fix. Throw the box away.
If you drive it now, don't get the lift pump diagnosed, use the box and it leaks. We learn nothing and you get ongoing grief.
Weather might play a part too. Is it cold there ?
Do you feel like a Guinea pig yet ?
Old Jan 11, 2006 | 04:51 PM
wexman's Avatar
My still-leaky CP3 (3 weeks now, dealer STILL waiting for backordered parts )is leaking less now that the weather has been about 50* these past couple days.
Old Jan 12, 2006 | 11:08 AM
sawboywv1's Avatar
O.K. SuperDuty I've got the FASS fuel pump on order.(I like ur setup,but this was easy) Box has been off since Tuesday. No leaking. 500 mile trip Saturday and if new pump makes it in and CP3S stays dry I will install on Sunday.
The more and more I thought about it the lift pump has to be weak.
Old Jan 12, 2006 | 11:40 AM
Superduty's Avatar
Wouldn't surprise me if the lift pump was weak.
Are you running the on engine or in tank ?
No prob. about the FASS.
Old Jan 12, 2006 | 11:55 AM
sawboywv1's Avatar
03 are Filter mounted
Old Jan 12, 2006 | 12:03 PM
Superduty's Avatar
I knew that. I was wondering if you had an in tank retro done.
I would be nice if you drove it for a bit more before touching anything, just to be sure.
Old Jan 12, 2006 | 12:22 PM
sawboywv1's Avatar
original lift pump with 53k on the clock. I am going to drive it about 600 miles more before I'll have a chance to replace pump. But box will stay off.
Old Jan 12, 2006 | 12:27 PM
Superduty's Avatar
Good man. Thanks for your contribution to Cummins science.
OT-OF-Here
Feb 16, 2007 01:29 PM
OT-OF-Here
33
Feb 3, 2007 10:10 PM
bigd6.6
Aug 22, 2006 05:53 PM
Superduty
48
Dec 30, 2005 11:23 PM
Superduty
0
Dec 23, 2005 10:52 AM
