Question about the Outlook Monitor
Old 04-30-2007, 11:58 PM
ScienceOfSpeed's Avatar
i have a 03 and i just hooked up my Outlook Monitor . i am running it along with a TST R37. everything works fine on the Outlook Monitor except for the boost reading. i also have an Autometer mechanical boost gauge and it works perfect, the Outlook will not read higher than 16psi at WOT but the Autometer reads 45psi at WOT, has anyone ran into this before, any suggestions would greatly be appreciated.
Old 05-01-2007, 12:23 AM
CrashCade's Avatar
Do you have it configured for the right vehicle?
Old 05-01-2007, 12:28 AM
yup, i have it configured for the 03-05 Dodge w/other
Old 05-01-2007, 12:30 AM
CrashCade's Avatar
Have you double checked your wiring? Is it plugged into the Map sensor right, maybe try some dielectical grease on the contacts?
Old 05-01-2007, 12:35 AM
i am gonna go back thru it and reinstall all the wiring
Old 05-01-2007, 12:43 AM
hey cade how many wires are in the Outlook monitor map sensor plug in on ur Outlook, because mine ony has 2 on the Outlook and there are 3 wires on my map sensor plug in on my truck.i had to get a new harness from Bully Dog, could they have sent me the wrong harness?
Old 05-01-2007, 10:58 AM
qzilla's Avatar
The Outlook gets its boost readings from the OBD2 port. If you plug any module in that does boost fooling like the TST then it will not read properly.
That is one of the main problems with reading data from the OBD2 port.
Old 05-01-2007, 11:33 AM
i was wondering if the boost fooling was messing something up, so when i take off my TST and go with the Diablo Predator/ Puck the boost portion of the monitor should work?
Old 05-01-2007, 01:11 PM
thanx everybody for the input, Qzilla u were right, just got off the phone with the tech dept. at Bully Dog, and the boost fooler in the TST is interupting the signal in the map sensor to send a correct boost reading thru the Outllok monitor, i greatly appreciate the help, thanx
CrashCade's Avatar
Quad, When did they start reading the boost from the obd2? I know before the triple dog came out there was nothing plugged into the obd2 port. I thought that is why the MAP sensor got tapped into.
I didn't think about boost fooling messing with it. That makes more sense though...
Old 05-01-2007, 02:40 PM
qzilla's Avatar
I am not sure. All the ones I have ever had used the oBD2 port. The MAP sensor is used for fueling or de-fueling and that is why it gets codes and makes the truck do funny things sometimes??
Hard to say what they are doing exactly.
Old 05-01-2007, 02:51 PM
Luken's Avatar
As long as you have a mechanical boost gauge I wouldnt worry about....
Old 05-01-2007, 07:27 PM
SmokinDodge12V's Avatar
I have an outlook on my truck and I dont even have boost as one of the displays for just this reason it is way off never goes below 4psi and no higher than 39psi while my Isspro shows a max of 42.
Old 05-01-2007, 08:28 PM
dieselkid6's Avatar
on 06+ they dont hookup too the data link plug or map sensor..it gets all info through the obd2 including boost..i have the boost fooler and my max boost the outlook reads is around 20-22
Old 05-01-2007, 09:08 PM
CButler610's Avatar
Like he said.
Get a mechanical boost gauge for accurate readings, especially beyond about 39 psi regardless of how the Outlook monitor plugs. I like mine. Good source of info. The '06 trucks have even more functionality.
kyle_truck_pull
03-31-2008 12:45 AM
dditt0635004x4
11-09-2006 09:51 AM
anestech*
26
11-15-2004 01:02 PM
anestech*
11-07-2004 12:18 PM
quantrill88
10-04-2004 11:36 AM
Quick Reply: Question about the Outlook Monitor
