Quaz XXT question
Quaz XXT question
Hi everyone's
Just install my Quaz XZT wooooooooow just took a small ride around and you can feel the difference.Can wait to see fuel economy.
I have a question could the Quaz as something to do with my day light they are not working anymore or it would be the flash the dealer made yesterday they did TST 18-036-06 or something close apparently it is the latest update. just wondering what happen.
Unless daylight don t come on when you shut the light at night.
Buzzman
Buzzman
I do not know what the reflash did for sure and I am certain someone on here can help you.
What I can do is assure you 110% that the XZT absolutely cannot affect the day time running lamps.
If you have any doubt the first step would be to disconnect the module and run the bypass plug in place of it. Make sure you do this with the truck off and the key out of the ignition.
Thanks that is all I need to know must be the reflash them and thanks Qzilla hope everything working out for your familly.
I will keep you post on the fuel consomption.
Buzzman
Buzzman
I guess so far I saw a improvement in fuel millage but I am not sure yet if it is the temperature outside affecting it it was in the minus 20-30degree celcius and now around -10Celcius but yes so far I have gain about 1 MPG hand calculate I guess we will see soon last tank was 19 MPG first time I was seing that number since I own the truck so looks good so far.
Buzzman
Buzzman
mkeanglorldo56
Nov 4, 2007 12:34 PM
Murf
Aug 17, 2007 04:36 PM
Oval Racer
Jan 26, 2007 02:57 PM
8mpg
May 8, 2006 06:37 PM
donhov
Dec 13, 2005 01:48 PM
