quadzilla m3
Old Feb 18, 2008 | 09:38 PM
southerman's Avatar
quadzilla m3
i hooked up my new quad. about a week ago and about 4 days after trans. started having problems, now it is at the dealership. could the quad caused the problem or was just time for the trans to go it has a 160,000 on it,they say the torque conventer maybe bad.truck shakes when taking off, and slipping in gear.
Old Feb 18, 2008 | 10:12 PM
marine4life's Avatar
The quad's not really the problem, it's your stock transmission. I wouldn't pay that much money to have them replace with another stock tranmission, spend the money on atleast an upgraded torque converter and valve body.
Old Feb 19, 2008 | 04:33 AM
slowflyer2112's Avatar
I just had the same problem on Friday, Trans just lost all power and slipping and bucking of the line. Dropped the pan and talked to my trans. guy and he said change the filter and fluid and go. Works great (fluid not burnt) I learned that as the temp goes up and with enough debris the filter will clamp shut (no flow) until it cools down, then it will work fine until it gets hot again and quite.
Check my sig.
Old Feb 19, 2008 | 03:34 PM
NoSeeUm's Avatar
That Quad box is notching up tranmission kills at a good clip.
WTG!
Jim
mopar440cu
Nov 21, 2015 08:39 PM
norcaljr
13
Aug 5, 2008 10:13 AM
Smokin98.5
0
May 29, 2008 05:35 PM
FireNhole
Feb 6, 2003 07:29 PM
