put a shot of acetone in the tank
Old Jul 6, 2004 | 08:08 AM
MST's Avatar
MST
Cleans injectors very well!!
Old Jul 6, 2004 | 10:04 AM
cquestad's Avatar
Any other observations? How much did you add?
Old Jul 6, 2004 | 10:45 AM
MST's Avatar
MST
bout a 1/4 cup to a fill up, runs alot smoother. I think an injector or two were dirty
Old Jul 6, 2004 | 10:58 AM
crobtex's Avatar
Be careful with Acetone! I worked with it for years, and it will eat up rubber compounds and plastics that other solvents won't touch.
Old Jul 6, 2004 | 11:16 AM
MST's Avatar
MST
your right, that's why I mixed it weak, and probly won't do it very often
Old Jul 6, 2004 | 12:31 PM
cquestad's Avatar
Anyone else doing this out there? I have read other postd\s/articles in the past, but it did not seem like to many were fond of this...
Old Jul 6, 2004 | 01:39 PM
thejeepdude's Avatar
I would think there's injector cleaners out there that would work just as well as that low ratio of acetone, without running the risk of degrading any rubber in the fuel circuit...
Old Jul 6, 2004 | 05:48 PM
amartinson's Avatar
With all the additives that already come in todays fuels, I can't imagine that adding a 1/4 cup of anything to a 30 gallon tank would have any benefit.
With that said, if I was going to put in an additive, it would be something specially designed for diesel engines such as Power Service or the like.
Old Jul 6, 2004 | 06:25 PM
ppsi's Avatar
I know a guy who swears by tranny fluid?? Any input/ideas
Old Jul 6, 2004 | 07:03 PM
Mexstan's Avatar
A few years ago I pulled an old Volvo out of a barn where it had sat without turning the engine for close to 10 years. I got it running after a bit of a fight but one injector refused to do anything, no matter what I did. So I removed the injector. blew it dry of gas and then filled it with lacquer thinners. Reinstalled it, connected up the lines, fired it up and let it idle. Within 5 minutes the injector came to life and the engine ran smoothly.
Lacquer thinner and other solvents such as acetone can damage rubber seals and other things but if used sparingly and briefly, then chances of damage is minimal.
Old Jul 7, 2004 | 09:25 AM
nickleinonen's Avatar
my pop use to use atf in every tank on his old 90 6.2 diesel. it worked for him [he never had any problems] but i don't think it would be good on electronic engines
Old Jul 7, 2004 | 09:52 AM
Mexstan's Avatar
Out of curiosity, why not? How/why would the electronics change the burning characteristics of the fuel with ATF added?
Old Jul 7, 2004 | 02:00 PM
Haulin_in_Dixie's Avatar
A gallon of black used engine oil burns fine in a full tank, guess a quart of atf would also...
piperca
Oct 23, 2005 01:19 AM
biglar
Sep 2, 2005 04:18 PM
jughead
May 30, 2005 06:15 PM
RockRover
18
Apr 14, 2005 12:56 AM
dss667
Mar 17, 2004 05:42 AM
