Pump Cover
Old 11-06-2003, 07:26 PM
Muted User
kyle@ftlb's Avatar
Pump Cover
Wondering if anyone could help me track down a pump cover for an 01' so i can run the fueling wire without voiding the warranty. I've called a couple places but they are out of them. Anyone know of anyplace online?
Old 11-06-2003, 08:58 PM
MLR1's Avatar
Re:Pump Cover
Sent a pm with info.
Old 11-06-2003, 09:06 PM
KatDiesel's Avatar
Re:Pump Cover
[quote author=kdawg62 link=board=7;threadid=22098;start=0#msg206738 date=1068168385]
[/quote]
Your warranty is still void with the cover.
Dr. Evil's Avatar
Re:Pump Cover
I think I have the same recommendation as MLR1
Old 11-07-2003, 09:43 AM
Palmetto_kid's Avatar
Re:Pump Cover
silly question, im new to 24v..i converted from a 12v.
what does the pump cover do...?
Old 11-07-2003, 09:46 AM
MLR1's Avatar
Re:Pump Cover
It taps the fuel selinoid wire on the pump without using the blue t tap that the edge & other boxes supply. It simply makes a better connection.
ps there is no such thing as a silly question ;D
Old 11-07-2003, 09:54 AM
Dr. Evil's Avatar
Re:Pump Cover
Ive been told that it can just about "hide" the fact that you have a fuelling box....
Old 11-07-2003, 10:05 AM
MLR1's Avatar
Re:Pump Cover
It does hide the tap as well but i bought mine for the better conection. One must be prepared to pay if one is going to play :
Old 11-07-2003, 10:39 AM
barracuda's Avatar
Re:Pump Cover
ive got one i bought new from Blue Chip and never took out of the wrapper ( my warranty was already void ), if u want it PM me
Old 11-07-2003, 01:44 PM
Diesel Freak's Avatar
Re:Pump Cover
[quote author=KatDiesel link=board=7;threadid=22098;start=0#msg206801 date=1068174398]
[/quote]
[/quote]
Not only that, but the electrical connection is no better than that of a Scotch Lock.
Old 11-07-2003, 08:31 PM
Muted User
kyle@ftlb's Avatar
Re:Pump Cover
I was told that your warranty isn't void if you dont splice into the wire. Could you explain why it is still void?
Old 11-07-2003, 08:37 PM
Administrator / Scooter Bum
Shovelhead's Avatar
Re:Pump Cover
The Techs can use their diagnostic equipment to pull fueling parameters out of the ECM showing that a Performance Enhancement had been installed even if it had been disconnected.
Dodge is training the techs on what to look for.
Old 11-07-2003, 08:41 PM
phox_mulder's Avatar
Re:Pump Cover
Dealers can and will void the warranty if an aftermarket part directly results in the failure of said warrantied part.
Piercing the wire was evidence that a fueling box was used, and if the injection pump failed, they blamed the box.
Tech would grab the magnifying glass and look for a hole in the pump wire.
No more warranty, fork over $1,300 for a new VP44 and a red flag on your VIN for future warranty work.
The pump cover another way to connect to the injection pump without leaving the tale tale "hole" in the wire.
VP44 dies, so you take it in for service.
Take the box out, put the OEM pump cover back on and take to the dealer for service the dealer wouldn't have any evidence of an aftermarket device being on the truck, and theoretically honor the warranty of the VP44.
In the old days this worked.
Now the Dodge technicians know what to look for inside the ECM, fueling parameters, DTC codes, etc.
Gone are the days of slipping one past the dealer.
Save your money and pierce the wire the old fashioned way, and be prepared to be your own warranty source.
phox
Old 11-07-2003, 11:35 PM
Trashdawg5050's Avatar
Re:Pump Cover
phox mulder,
do you know where they view those area with the DRB
Old 11-08-2003, 02:37 PM
Re:Pump Cover
[quote author=Trashdawg5050 link=board=7;threadid=22098;start=0#msg207248 date=1068269738]
phox mulder,
[/quote]
Not sure I understand the question.
What Utah Dealers know how to do this maybe?
I'm sure by now it has trickled down to all of them, as far as the knowledge.
Which ones put out the extra effort to check, I have no idea.
My experience with a couple of the local Dealers, you're pretty lucky to get a competent Diesel mechanic at them.
The 2 I've frequented only have one Diesel guy on staff, and he's kept pretty busy (or so they say)
As stingy as STAR (the warranty OK'ers) is green lighting warranty work (took a week to get my VP44 when it died, unbombed) I think they'd be forced to check everything.
If they miss something, Bosch (the pump manufacturer) runs their own tests and will deny warranty, so the Dealer has to pay if he fixed it under warranty.
Dealer is in it to make money, so less and less of them are willing to look the other way, as some have in the past as well.
Hoops will be jumped through if and when you take your truck in for engine related warranty work.
Take it in for a leaky door seal, it'll be hard to blame that on the fueling box.
They'll probably think up something though.
Don't play if you aren't willing or able to pay.
phox
Quick Reply: Pump Cover
