PS Pump repair
Old Apr 3, 2003 | 04:48 PM
bigredbrick's Avatar
PS Pump repair
Any tricks to R&amp;R ps pump and replace it's seals? ???<br>One of these years I'll get a manual! :<br>Thanks, Chris
Old Apr 8, 2003 | 12:40 AM
Re:PS Pump repair
I was wondering if it's possible to separate the ps pump from the vacuum pump on the truck. The instructions in the Napa seal kit don't look too difficult. Hasn't somebody out there done this?<br>Chris
Old Apr 19, 2003 | 08:41 AM
Monty's Avatar
Re:PS Pump repair
Yes the vacumn pump and steering pump can be removed seperately. Between the two is a 2 bolt flange. Remove the nuts that hold the two together. Once apart, you will see the cross shaped drive coupling that the drive tangs ride in. Around the 2 bolt flange is an O-Ring. This will probably be in your kit as well as an oil shaft seal. After you have installed the kit, line the drive tang up with the drive coupling and tighten the nuts to the flange.<br><br>
Old Apr 19, 2003 | 11:44 PM
Re:PS Pump repair
Thanks for the reply Monty. Now I just need to find the time to do it!<br>Chris
Mike D
Feb 15, 2007 05:57 PM
lizrules
Feb 1, 2007 05:50 AM
Alan_Reagan
17
Dec 28, 2002 07:57 AM
Lary Ellis (Top)
Nov 15, 2002 11:00 AM
