Propper torque specs, any help?
Old 07-22-2011, 05:47 PM
freight train's Avatar
Hi, I was wondering if someone could help me out. I am looking for the proper torque specs for these items on my 1990 motor. I am swapping on a few items so I can run a 1993 engine harness on it. Here is the list:
1. 4- vibration damper bolts
2. 4- air intake horn bolts
3. 10- air intake plate bolts
4. 2- front timing cover bolts to install the crank sensor
5. And valve cover bolts? I am putting a second gen cover on them and need to pull #1 and #6 bolts out to install the studed ones to use the cover
My dad has my 1992 factory manual at his shop and he seems to have misplaced it. I appreciate anyones info. Thank you
Old 07-22-2011, 05:54 PM
joeytechman's Avatar
In the sticky, last one under engine.
Old 07-22-2011, 06:33 PM
^thank you
Here is whats on there unless I missed it. Or I didnt recognized it.
1. 4- vibration damper bolts (92ft-lbs
3. 10- air intake plate bolts (18ft-lbs
4. 2- front gear cover bolts (18ft-lbs
5. 2- valve cover bolts (18ft-lbs)
I found everything but the 4 air intake horn bolts. They seem long, I dont want to snap them off. Can one of my fellow Cummins friends please chime in to help me out?
Old 07-23-2011, 09:20 AM
bgilbert's Avatar
They're all 18ftlbs expect the 4 balancer bolts at 92ftlbs.
Old 07-23-2011, 06:17 PM
Thank you, I took care of it this morning
mossyoak11
02-06-2013 10:17 AM
lniemeyer2
10-24-2012 12:11 PM
06RAMCTD
0
12-19-2006 04:15 PM
Lary Ellis (Top)
02-23-2003 01:10 PM
Quick Reply: Propper torque specs, any help?
