Proper way to block a wastegate
Old Apr 14, 2006 | 01:41 PM
TxDiesel007's Avatar
Just curious,
Is there a "proper" way to block a wastegate? or can you just get a longer hose, pinch it and somewhat get the same effects? I have read up that some people stick a screw in the line that goes to the gate, others just remove the hose completely, if you plugged ur gate, how did you do it and what became of the hose? was it completely removed? OR was it just left to dangle...
Thanks guys
Still learning as I go..
Rick
Old Apr 14, 2006 | 01:55 PM
high country's Avatar
you can buy adjustable boost elbows
Old Apr 14, 2006 | 03:23 PM
HOHN's Avatar
I use an eighth inch pipe plug...
Old Apr 14, 2006 | 04:05 PM
MasseyMan1089's Avatar
MIne didnt work when I got the truck. I guess its rusted closed? I dont know, but it doesnt bother me any! 40# of boost!
Old Apr 14, 2006 | 04:38 PM
dodgeguy71's Avatar
I have heard of truckers putting bb's or pellets in the hose.....you know cause it's not legal or something, so they have to be crafty and do it so it looks like the hose is still connected and functional..maybe something about DOT??
Old Apr 14, 2006 | 06:53 PM
Forrest Nearing's Avatar
I yanked mine, shoved a bolt in the hole, and hose clamped it
Old Apr 14, 2006 | 07:45 PM
infidel's Avatar
Same here, on a bunch of them, a 1/4" bolt works for me.
Old Apr 14, 2006 | 09:31 PM
mxjunkie80's Avatar
Pictures anybody?
Old Apr 14, 2006 | 09:36 PM
Jaxn51's Avatar
Ditto......unscrew the fitting from the turbo and screw in the plug, nothing else to do.
Done
Old Apr 14, 2006 | 09:56 PM
durasmack's Avatar
1/8 plug on the one end.... 1/8 cap on the other end to keep the dirt out.
Old Apr 14, 2006 | 10:45 PM
torquefan's Avatar
I've always adjusted the rod on the actuator to set the max boost wherever I wanted it.
Old Apr 14, 2006 | 10:49 PM
Cummins4Life's Avatar
Old Apr 15, 2006 | 11:21 AM
one54ton's Avatar
I actually tried the vise-grip method and got like 4+ lbs of boost more.
Old Apr 15, 2006 | 11:44 AM
01smoker's Avatar
With all of my mods I could only hit 30 psi. So yesterday I put a plug in it and now I hit over 40 psi.
Old Apr 15, 2006 | 02:05 PM
Timberman's Avatar
What could go wrong if you put a bolt in the tube? Can you tow with it like that? Guess you just have to watch your boost gauge. I'll do that today if it won't kill something expensive on my motor.
