Problems with fuel solenoid
Old Oct 23, 2007 | 05:30 PM
big jimmy's Avatar
I put in a new one yesterday but when its cold it will not pull up. I put in all new relays and the fuel solenoid.
Any ideas?
I have continuity from the battery and obviously the hold circuit works just fine. So the issue is in the pull up circuit.
Big Jimmy
Old Oct 23, 2007 | 06:55 PM
Rare1's Avatar
The oft-repeated wisdom on this forum is that fuel solenoids rarely fail, most are replaced needlessly.
Does it move at all when the key is turned? Did you adjust the initial position correctly? Did you bench test it before installation? Did you bench test the old one after removal?
You say the hold circuit works just fine, so I would say the solenoid is OK. The initial position is critical because the plunger must be partially inserted into the coil for it to actuate.
Old Oct 23, 2007 | 07:00 PM
infidel's Avatar
Check that the small brown wire at the starter has a good connection.
This is the wire that triggers the relay to close for pull.
Also check the blue wire at the battery positive isn't corroded, this often happens under the insulation where you can't see it.
Old Oct 24, 2007 | 06:20 AM
pappyman's Avatar
I agree with Infidel check the blue wire at the battery it causes this type of problem its a simple fix but most people over look it
Old Oct 24, 2007 | 08:58 AM
big jimmy's Avatar
Thanks.
Jimmy
dodgediesel
Apr 15, 2010 09:00 PM
jasonfriedlin
Jan 2, 2010 08:24 PM
65fury
Jan 21, 2007 10:31 PM
Tim9712v
16
Mar 3, 2005 07:09 PM
hhwright
Dec 15, 2002 03:39 PM
