PML diff cover...anyone paint theirs?
Old Jan 19, 2011 | 09:28 PM
VaultRam's Avatar
Just wondering if you've painted your as-cast finish cover?
Old Jan 20, 2011 | 05:15 AM
Almond Pale Ale's Avatar
No paint here. I think only dark colors would look good, surface isn't finished well enough to produce a quality shine with paint.
Old Jan 20, 2011 | 06:29 AM
Guardrail's Avatar
I coated my factory one with bedliner material.
Guardrail
Old Jan 20, 2011 | 11:17 AM
VaultRam's Avatar
I was thinking of ordering the rear cover in as-cast finish and painting it with like a hi-temp flat black. Might have to sand it good to get the paint to stick, maybe primer too
Old Jan 20, 2011 | 11:56 AM
ripping r's Avatar
I ordered the powder coated one. and the cover is nice. there powder coating is not. i think it's just paint.
Old Jan 20, 2011 | 12:02 PM
jpfishmaster's Avatar
I painted mine in a hi-temp enging paint that is gray and looks great and has held up perfectly
Old Jan 21, 2011 | 03:35 PM
.boB's Avatar
Guardrail
Probably not the best choice. Bedliner is a pretty fair insulater.
Some high temp engine enamals contain ceramic. That's a pretty good insulater, too.
PC or a light coat of enamel shouldn't effect heat transfer enough to matter for normal use. If you're going to hauling or racing in the desert, there are some specialty coatings available that promote heat transfer, and will almost suck the heat out of the oil
Old Jan 22, 2011 | 06:49 AM
Condor's Avatar
I painted both front and rear with krylon gloss black, 3 coats then took a flat file to take the paint off the fins. Looks just like the power coated one. Prep the outer surface first, I used brake cleaner spray to wash off any oil film and dirt that was on it. Has held up fine, been 3 yrs now.
SundayMoney
Sep 1, 2008 06:55 PM
Lightman
Apr 18, 2005 02:09 PM
HighTen
Feb 23, 2005 02:51 PM
davelinde
31
Jan 28, 2005 05:38 PM
MikeyB
13
Jan 24, 2005 07:16 AM
