PML diff cover and Mopar fender shields installed
Installed the PML diff cover for the 11.5" AAM. Very well made and looks good, even on a dirty axle. Required 5 qts of fluid to bring the level up to the check hole.
Also installed the Mopar fender shields.
Pics are in my photo gallery.
MikeyB
MikeyB
MikeyB,
Looks great! But I have a guestion, my BFG 315 spare just barely gets by the stock cover. Does it stick out any farther along the radius for the ring gear than the stock cover? Thanks, Jerry
Jerry R,
Yes, it does. This is from just eyeballing it and not actually measuring before and after (guessing about a 1" or so).
I will go out and measure both covers today and reply back with the answer.
MikeyB
MikeyB
From: Smith Valley, NV (sometimes Redwood City, CA)
Jerry,
That's a good question. I just had my 315 spare out and had to do some jiggling around to get it to clear the stock cover.
Wetspirit
Wetspirit
Wetspirit,
I know what you mean. I have to hold my spare to the rear while cranking up tight to get it to clear. But I sure would like to change gear oil without pulling the whole cover.
Here's the measurements between the stock cover and the PML for the Dodge. These are rough estimates measured from the gasket flange. The measurements show that the PML is about 1" thicker than the stock cover.
Stock cover measured at the first radius at the top 1". Maximum depth 3"
PML cover measured at the first radius at the top 2". Maximum depth 4"
MikeyB
MikeyB
Re: O-Ring ?
Originally posted by lucey
Is this cover a O-ring cover like the Mag-Hytec ?
MikeyB
Switching to the other half of your project, how are the Mopar fender shields attached? Hopefully it is with screws going into existing holes like for the factory bug deflector you have. I think they look really sharp!
Fredbert,
The fender shields are attached with the push pin style screws and double sided tape. The edge of the fender shield slips under the rubber seal that is between the fender and the grill. Just remove the one push pin that holds the rubber gasket on. The other hole is already on the fender. The double sided tape attaches the shield just above the headlights. A 5 minute job and it appears to be pretty solid.
MikeyB
MikeyB
DREDnot
Oct 1, 2007 08:03 AM
HighTen
Feb 23, 2005 02:51 PM
davelinde
31
Jan 28, 2005 05:38 PM
MikeyB
Jan 11, 2005 09:02 AM
MikeyB
Feb 6, 2004 12:12 PM
