Please explain 1/8" NPT Pipe tap
Old 04-02-2007, 12:45 PM
koogala's Avatar
Can someone PLEASE explain how they come up with the name 1/8" NPT
pipe tap.
I installed my thermocouple this weekend & used it. 1/8" npt seems to be a standard for this tap. All other taps are named by thier true diameter.
The 1/8" NPT tap is NOWHERE NEAR 1/8" (.125) It is more like 11/32
Old 04-02-2007, 12:47 PM
P.J
P.J's Avatar
National Pipe Thread.
It is based on the inside diameter (ID) of the actual pipe that will be threaded into it. So, adding up the wall thickness' of the actual pipe material, plus the ID.....
(I think)
Old 04-02-2007, 12:58 PM
RustyJC's Avatar
From a pipe fitting manufacturer:
Pipe Thread Sizes
Originally, pipes were specified with a standardized outside diameter (OD) and wall thickness so that the nominal pipe size would approximately equal the inside diameter (ID).
Rusty
Old 04-02-2007, 01:00 PM
koogala's Avatar
???... You then would have a pipe smaller than 1/8". Its crazy to me.
Why not be like all the other taps & name it by the DIAMETER IT IS.
Back to the salt mine!
Old 04-02-2007, 01:29 PM
Mark1si's Avatar
I agree with ya on that one.
Old 04-02-2007, 01:34 PM
RustyJC's Avatar
I dunno....it took me a long time to figger out why the jaws of a 1/2" open end wrench weren't 1/2" apart!
Rusty
Old 04-02-2007, 04:22 PM
koogala's Avatar
Rusty
Oh my gosh! They've been short-changing us on our inches...
The drag race I went to the other day.....Sign said "1/8 mile tonite only"
It was a 1/4 mile track. It was tore up from an accident the previous nite.
I asked the lady in the ticket booth if the tickets were 1/2 price then...She got all flustered with me...No sense of humor
Old 04-02-2007, 04:53 PM
C Schomer's Avatar
The ID of schedule 80 iron pipe runs really close to the nominal size. Sch.40 (the common hardware store stuff) is thinner wall. Craig
Old 04-02-2007, 06:27 PM
bkrukow's Avatar
(I think)
What he said. It is based on the diameter of the ID of the pipe that is going to be threaded into it. The size of the tap is roughly the ID of the pie, in this case 1/8 + twice the wall thickness of the pipe.
There is also a diference in the hole diameter that you drill if it is a NPT or NPTF. The NPT is a bigger hole and requires the use of thread sealent such as teflon where NPTF uses a smaller hole and has tighter tolerences and is a dry seal so theoreticly you dont need any thread sealent.
Old 04-02-2007, 06:29 PM
qzilla's Avatar
Also remember that the idea behind the NPT is that it is a tapered thread so it seals properly and won't leak.
You can get away with a standard size tap (can't remember exactly which one) and still screw the thermocouple in but, it will be straight walled threads and will leak.
Old 04-02-2007, 06:32 PM
bkrukow's Avatar
Your close but read the last couple lines of what I posted above.
LovinTheTorque
09-14-2013 12:02 PM
glarior
05-17-2011 07:46 PM
JyRO
25
09-19-2007 07:24 PM
SolarYellow05
05-18-2006 08:50 AM
Hoss
04-11-2006 11:37 PM
Quick Reply: Please explain 1/8" NPT Pipe tap
