Pick One More Gauge
Old Feb 19, 2009 | 05:24 AM
Ace's Avatar
Ace
Pick One More Gauge
So I'm putting boost and EGT in the A-pillar and I have low side fuel pressure and trans temp in a custom mount down in the cubby hole below the heater controls. There's room for one more gauge on that mount. What should it be and why?
(07' 5.9 48RE, pretty much stock and staying that way)
Old Feb 19, 2009 | 05:46 AM
05HDRAM's Avatar
I would say either Rail Pressure because it is nice to see both sides of fuel delivery, or Oil pressure because the stock gauge gives you no idea of what the actual pressure is.
Old Feb 19, 2009 | 06:31 AM
madhat's Avatar
Administrator/Jarhead
I would say rail pressure, but you are saying that you will be staying stock... this is on the 07, right?
Yeah... after sitting here and thinking about it, rail. If you start having a FP problem post LP gauge, you can tell. Oil would probably be my next choice, then rear diff, if you tow a lot...
Old Feb 19, 2009 | 08:13 AM
jgiachino's Avatar
I vote Rail Pressure
Old Feb 19, 2009 | 08:25 AM
mishkaya's Avatar
My first choice would be Rail Pressure. Let's you know if there is a problem with stuck injectors or cracked injector bodies and such.
My second choice would be oil pressure as the cluster gauge is a dummy.
mishkaya
Old Feb 19, 2009 | 08:35 AM
homewrecker's Avatar
Rail Pressure for sure.It is instrumental for trouble shooting should you ever have a fuel system related problem.
Old Feb 19, 2009 | 09:54 AM
gmctd's Avatar
Rail Pressure also gives instantaneous indication of fuel consumption...........
Old Feb 19, 2009 | 07:33 PM
Ace's Avatar
Ace
I had a feeling rail pressure was going to get the nod. So which one? I got Auotometer Ultra Lites for the others and it doesn't look like Autometer makes a rail pressure gauge that I can find. Guess I'll have one odd non-matching gauge, just like the other truck. It's got a bunch of Autometers and an ISSPRO tach.
Old Feb 20, 2009 | 09:11 AM
AH64ID's Avatar
On a basically stock truck i would go Oil Psi...
Old Feb 20, 2009 | 09:42 AM
gmctd's Avatar
Checkout the Pricol Optix lineup, usually called DiPricol...............
From my Liberty KJ CRD - uses the same Bosch CP3 as Cummins:
SmokenRam
13
Apr 6, 2009 09:27 PM
Common
May 20, 2007 12:12 PM
KVD
Apr 25, 2007 12:47 PM
Ole JIM
Mar 12, 2007 11:23 PM
sluggo42
33
Feb 2, 2007 11:30 AM
