Parts Help
Old 07-06-2007, 07:04 PM
PeteRR's Avatar
Parts Help
I've decided to finish the engine compartment by sourcing parts for the A/C system in my Cummins conversion. The 118 degree days around here have driven me to it. The '93 CTD is installed in my '75 crewcab. Unfortunately I lost a bunch of parts damaged when my donor truck was wrecked. What I need is a list of parts for the A/C system including the part numbers. This will help me with the local parts suppliers. A diagram would be helpful also. Thanks in advance.
Old 07-06-2007, 11:30 PM
searcher's Avatar
I guess the first question is "Does your '75 have the cab components (evaporator and blower motor) installed? Are you using a Cummins radiator? That would determine what condenser you would use. If you have the compressor brackets then you can look up the compressor you need on Advance Auto Parts website. Do you still have the AC hoses from your donor truck? It doesn't matter if they are no good as long as the connectors for the components are good.
Old 07-06-2007, 11:34 PM
PeteRR's Avatar
Yes.
Yes.
Unfortunately no.
Since they were damaged in the wreck, they weren't installed and I didn't ask for them when I picked up the completed conversion. I probably should have.
nbaggett89
12-26-2015 09:36 AM
Checkmate
03-02-2008 05:55 PM
BRUISER
05-02-2007 09:20 AM
CTD_Neil
07-19-2005 08:13 PM
xj2extreme
02-20-2003 10:38 PM
Quick Reply: Parts Help
