Parts Help
I've decided to finish the engine compartment by sourcing parts for the A/C system in my Cummins conversion. The 118 degree days around here have driven me to it. :o The '93 CTD is installed in my '75 crewcab. Unfortunately I lost a bunch of parts damaged when my donor truck was wrecked. What I need is a list of parts for the A/C system including the part numbers. This will help me with the local parts suppliers. A diagram would be helpful also. Thanks in advance.
I guess the first question is "Does your '75 have the cab components (evaporator and blower motor) installed? Are you using a Cummins radiator? That would determine what condenser you would use. If you have the compressor brackets then you can look up the compressor you need on Advance Auto Parts website. Do you still have the AC hoses from your donor truck? It doesn't matter if they are no good as long as the connectors for the components are good.
Originally Posted by searcher
(Post 1587262)
Are you using a Cummins radiator? That would determine what condenser you would use. If you have the compressor brackets then you can look up the compressor you need on Advance Auto Parts website. Do you still have the AC hoses from your donor truck? It doesn't matter if they are no good as long as the connectors for the components are good. |
