P2509 Code?
Old 09-24-2009, 01:39 PM
Nate-03 D's Avatar
P2509 Code?
A little info. 04.5 Dually, auto tranny w/ 145,xxx on the clock. Was leaving my house for work and got halfway down the driveway when the truck just completely shut down, no power no where. Stopped and restarted truck, no CEL showing on the cluster.
Smarty says P2509, "Powerdown Data Lost Error". Anyone know anything about this?
Also, this has happened a few times. While driving, at random times I loose my throttle. You can hit the pedal but nothing happens. The truck doesn't die, you just can't accelerate. I have to pull over and shut her down then begin back on my way. I' m thinking that it is something w/ the throttle position sensor?
Old 09-24-2009, 02:27 PM
cozzo1000's Avatar
I had that error code recently when my batteries were weak and ready for replacement. The gauges were bouncing around and the transmission would not shift right. The motor also turned over slowly when starting.
Old 09-24-2009, 10:36 PM
Nate-03 D's Avatar
I was thinking it was batts going bad also but the truck does crank over and pops off without hesitation. I did notice that when I first put the key in the ignition that the speedometer bounces to 60 then back to 0, do 04.5 do that? I know my 03 doesn't.
When ever the truck is shut down then restarted the radio always resets it's self. Then I noticed today that when I left for lunch and went to get back in my truck my key fob wouldn't unlock the doors, had to open it manually. I tried hitting the unlock button on the switch panel to let my buddy in and it wouldn't unlock for me. Maybe all these issues are tied together?
I 'm going to load test the batts tomorrow and see where they stand.
Old 09-24-2009, 11:05 PM
Det 1's Avatar
Hmmm. I wonder if only one of your batteries is going bad. I know each battery is responsible for different functions, but I can't tell you which is responsible for what. The speedometer on my truck doesn't bounce at all upon starting the motor.
Old 09-24-2009, 11:18 PM
cozzo1000's Avatar
Lots of oddities happen when the batteries start going bad. The speedometer and tach ping when the key is turned on. Getting the batteries checked is a good starting point - you're on the right track.
Old 09-25-2009, 08:35 PM
annabelle's Avatar
Have the same thing.....I have replaced both batteries(no help) I have now replaced the Gov. pressure solenoid and sensor......will know in the morning and report........one of my batteries shorted to cause this mess.
JARHEAD
03-05-2020 01:08 AM
ROOSTER108BM
05-27-2007 11:39 AM
Nuttymopar
04-26-2005 08:16 AM
kertoncol
01-19-2004 10:18 AM
Quick Reply: P2509 Code?
