P Pump question
might wanna double check, but i think you may need the cam out of that motor as well. i could be wrong but that's what i've read from others doing a p-pump swap. of course you may know, you'll need high pressure lines, pump gear, pump mounting bracket, timing cover, shutdown solenoid functionality, throttle cable hook-up and oil lines for internal pump lubrication.
I'm going to be p-pumping my truck here pretty soon an was thinking of getting a turbo too, do u guys think the he351 would be good with a p-pump or should I just go ahead an get a phatshaft 62 or bigger. My pump is a 215hp pump if that helps
get something bigger than a he351, it would be a waste of money and time.
