odd oil change
Old Jul 21, 2007 | 02:14 PM
00sport's Avatar
odd oil change
in the process of changin oil now. just pulled the filter and it was only half full. i have never seen this before whats the deal. only 5500 miles on oil, wix filter crankcase full. oil pressure is normal on dash guage. the gauge delays about 4 sec. after every crank is that normal. all other vehicles iv messed with the filter was slam full and leaks out. do i have a problem or am i worrying too much.
Old Jul 21, 2007 | 04:33 PM
J BODY's Avatar
I find at work most filters are 3/4 to 1/2 full when removed.......unless it's a Mopar, Fleetguard, or Cummins filter. The yellow one, orange one, any napa, and a host of others make for a clean job when doing an oil change.
Old Jul 21, 2007 | 05:48 PM
00sport's Avatar
So... sounds like it aint hurt then. Good deal. I knew it was gettin oil cuz i could see it on the valve train through the filler hole.
Thanks J Body
Old Jul 21, 2007 | 06:13 PM
dieseldemon's Avatar
Most filters do not have a check valve in them and will drain back in about 1 hr.
Old Jul 21, 2007 | 06:39 PM
cmac's Avatar
that is also why it takes a few seconds to get oil pressure at start up... most filters like stated above allow the oil to drain back into the pan... k&n also has a valve to prevent this...
Old Jul 21, 2007 | 11:35 PM
00sport's Avatar
intresting put a mobile one filter on this go round will see how it does.
Thanks yall
jmccart
13
May 27, 2009 09:45 PM
doitl8r
Jun 4, 2004 11:14 AM
snice
Apr 29, 2003 08:41 PM
