what now?
Old 04-15-2011, 08:00 AM
tndiesel's Avatar
what now?
my truck now has 216K miles
things I've done
-front ball joints
-ebc greenstuff brakes all around
-new power steering hoses
-change oil & coolant regular
things haven't done:
-change differential fluid
-change tranny fluid--(still looks brand new, must be synthetic?)
-change fuel filter--(stupid not to I guess)
On the fuel filter do I just drain, put in new one and restart?
Old 04-15-2011, 09:03 AM
Dr.Dizzle's Avatar
things I've done
-front ball joints
Removing and refilling the gear oil is a simple process and the gaskets are reusable.
ATF+4 FLUID is synthetic; however, the looks are not a good indicator of the fluids condition.
Pick up a Baldwin PF7977 fuel filter and use the following process in the link provided below to perform the replacement. This very informative article was submitted by member HorseHauler and found in the DTR wiki.
http://wiki.dieseltruckresource.com/..._Filter_Change
Old 04-15-2011, 09:07 AM
Adaminak's Avatar
REPLACE YOUR FUEL FILTER!!!!!!!!! Do it today. Do it now. Go to your nearest Cummins dealer and buy a Fleetguard filter, or go to a Dodge dealer and buy their rebranded filters. Do NOT wait for a shipment of Baldwin or Donaldson filters to arrive.
Replace the K&N filter with an Amsoil of AFE or AEM. Do a search for K&N air filters and you'll understand why. Just not worth the possibility to me.
Old 04-15-2011, 11:01 AM
tndiesel's Avatar
Oops, forgot to mention I did replace the air filter. Why do I not need to wait for delivery of a Baldwin fuel filter?
Old 04-15-2011, 11:14 AM
torquefan's Avatar
I would sure be servicing the differentials and transmission too. I'm pretty fussy about changing
That stuff every 30k or so.
Old 04-16-2011, 02:43 AM
Adaminak's Avatar
Because it will take anywhere from 3-7 days to arrive, and you need to get your 200,000 mile overdue fuel filter out now...
Old 04-17-2011, 08:39 AM
tndiesel's Avatar
Quick history, I bought truck with 192K miles from one owner who had it serviced at dealer religiously. He had fuel filter changed at recommended intervals but I haven't changed it since I bought it with 192K miles.
Old 04-17-2011, 04:52 PM
Adaminak's Avatar
Got it...that's a little less worrisome! I'd still replace the filter as soon as possible and then at the next scheduled service have the Baldwin on-hand. I'd also suggest a change of differential lube as eventually it will get water contamination over time. 200K miles is a lot of use, and lube is cheap insurance...
moparmatt
05-01-2015 08:49 AM
Shorts
06-29-2013 09:23 PM
95ram
07-28-2010 02:17 PM
ramlovingvet
03-22-2003 08:32 PM
cfm3110
03-18-2003 10:54 AM
Quick Reply: what now?
