No dash lights
Old Nov 29, 2010 | 04:49 PM
Onemoparnut's Avatar
No dash lights
My dash lights quit working today. Everything else works ok just no dash lights. I checked the fuse and swapped out the headlight switch with a spare I have and they still dont work. I looked at the schematic in the sticky and there is power at terminal I on the headlight switch but I loose where it goes after that. Can anyone point me in the right direction???
Old Nov 29, 2010 | 05:20 PM
Ok I was looking at the fuses wrong and I did have a blown fuse. I replaced it and it blew again right away. I have the gauge cluster unhooked and all my isspro gauges and the heater control light are unhooked. The fuse still blows am I forgetting a dash light anywhere???
Old Nov 29, 2010 | 06:11 PM
befitz's Avatar
Did the fuse blow before you turned the lights on?
Old Nov 29, 2010 | 06:28 PM
No as soon as you turn the lights on it blows. I think I found a short near the radio. I was using a very bad method of finding a short where you just look for smoke and I saw smoke near the radio and the wife saw a spark. I took the radio out and the short is gone dash lights work again. I pot the radio back in and all is good I couldn't find a chaffed wire anywhere. I hate when this happens cause you know it aint fixed and is gonna mess up again it is just a matter of time.
Old Nov 29, 2010 | 06:41 PM
befitz's Avatar
If you put a 1/2 amp in-line fuse in the wire to the radio it would probably blow before the 3 amp fuse feeding all the instrument lights. Need to put the fuse as close to the instr panel as possible. Of course
you need to find the short at some point. When I look for a short I pull the fuse that's blowing and connect a test light across the fuse receptacle. The light will stay lit til the short is found.
Old Nov 29, 2010 | 06:47 PM
ofcmarc's Avatar
Check out the light for the Cigarette lighter/ash tray. The housing for mine shorted and caused all kinds of headache to figure out.....
Lots of little things fees off the wire after the headlamp switch. gotta follow the diagram very carefully......
Old Nov 29, 2010 | 06:58 PM
That is a good piece of info right there thank you!!!
Old Nov 29, 2010 | 07:00 PM
I guess I dont thoroughly understand the wiring schematic the wire only goes to the end of the page how do you know where it goes to after that??? For now it is working but I know it is not fixed however I cannot seem to get it to mess up again and I cannot seem to find a bare wire anywhere.
Old Nov 29, 2010 | 07:12 PM
ofcmarc's Avatar
Follow the wire across the page to diagram #25. http://dens-site.net/Dodge_CTD/1991....ams/Scan25.jpg The wire near the top labeled 20OR is the wire out of the headlamp switch. It goes to the splice labeled E2. The E2 is surrounded by a diamond. Where the diamond points to is a large black dot that has several wires coming out of it. All of those wires go to other lights and what not. Anything attached to those wires can cause the blown fuse you had......
I got to follow most of them a couple months ago as well. A real PITA.
Old Nov 29, 2010 | 07:17 PM
befitz's Avatar
Y'all probably know this, but just in case, 200R stands for 20 gauge wire
with orange insulation. I just figured it out, duh.
Old Nov 29, 2010 | 07:19 PM
ofcmarc's Avatar
There is always someone new to this out there that just learned something from your post.
Old Nov 29, 2010 | 07:23 PM
gadget.35-06's Avatar
Try using some 20-mil pipe wrap as extra insulation where wires are likely to be pinched. Comes in a roll an inch-and-a-half wide and works pretty well as a protective wrap for wire bundles.
Old Nov 29, 2010 | 07:46 PM
Originally Posted by ofcmarc
Follow the wire across the page to diagram #25. http://dens-site.net/Dodge_CTD/1991....ams/Scan25.jpg The wire near the top labeled 20OR is the wire out of the headlamp switch. It goes to the splice labeled E2. The E2 is surrounded by a diamond. Where the diamond points to is a large black dot that has several wires coming out of it. All of those wires go to ohter lights and what not. Anything attached to those wires can cause the blown fuse you had......
Thanks for the explanation I was kinda lost.
Old Nov 29, 2010 | 07:47 PM
Thanks for the help everyone.
NoSparkplugs
17
May 17, 2009 10:36 PM
craneage2001
Nov 9, 2006 07:07 AM
larry30000
Feb 26, 2006 06:29 PM
eric13
Oct 17, 2005 07:05 PM
CHarlan
Aug 6, 2003 08:40 PM
