what next???
what next???
finally got everything I thought i needed
any suggestions on what next?????? I use my truck for a daily driver and some towing and hauling 7-8k. The mods done are pyro/boost gauge,low stall tq convertor,shift kit,5" exhaust,pod,s, fuel pin,16cm housing,intake,happy screw turned in,AFC turned way in and only hitting 900 on pyro???
900 with PODs? seems like a bunch of guys are 1600 easy with mostly stock turbo's. More Fuel? piston pump, electric helper pump?
Probably closer to 1100 or so pre turbo. If you stand on it from a stop at WOT you should have no problem getting it past 1250* pre turbo, especially with those injectors and the mods you have. Temps will also be higher pulling a trailer. Just get a pre turbo pyro and watch it when you're pulling.
At peak HP I think you can go to 950 post turbo continuously, most people seem to like the pre-turbo reading though(more accurate). If you are happy with the power and are towing, I would just leave it be unless you are looking for big #s.
Post turbo 950* ?? I have run at 1100* to 1200* POST
for a loooooong time and NO ILL effects. I did dump the
16cm and go back to the 18 for better mid range. I do NOT
like the pre-turbo because I lost a turbo and an engine when
the sender burnt off, total cost $15,000 for a new engine.
With PODS it should be SMOKIN' after about 1 minute
59
59
CurtisvilleCummins
Mar 10, 2003 02:24 PM
