Newbie Question
Old Jun 28, 2006 | 06:09 PM
texguy2124's Avatar
Newbie Question
What are the biggest tires I can fit under my 2006 Quad cab 4X4 without any lift mods? Thanks for any help anyone can give me.
Old Jun 28, 2006 | 09:46 PM
35" 05''s Avatar
33's without leveling kit. 35's with.
Old Jun 28, 2006 | 10:37 PM
TxDiesel007's Avatar
I have seen many guys put the H2 315s on stock rims with no lift and it works, now 315s are 35's correct? If so i think thats as large as u can go..
Rick
Old Jun 29, 2006 | 09:28 AM
TurboGoat's Avatar
I have Nitto Terra Grapplers 295/70/17s on factory suspention and as far as i can tell, I am no where close to rubbing. They are approx. 33.5 inches tall. I am also looking into 315s. Aftermarket wheel backspacing is the main concern. I have been told that I can put a 315 on my factory rim/suspension setup and rub only slighly in extreme turning or bouncing condidtions. However, if you put the same tire on a wide rim with greater Bspacing that it will still rub with a leveling kit. Anyway, thats just what I have been told.
Old Jun 29, 2006 | 10:45 AM
derek840378's Avatar
315/75-16 & 315/70-17 are both 35"
Old Jun 29, 2006 | 11:23 AM
TurboGoat's Avatar
Not to get too overly technical, but they are both a little smaller...about 34.5"
http://www.bfgoodrichtires.com/asset...rain_ta_kd.pdf
http://www.nittotire.com/popup_terra_sizes.asp
Old Jun 29, 2006 | 12:25 PM
here's some more "not to get too overly technical". well, actually it is
if you do the math:
315/75-16 is 34.6
315/70-17 is 34.4
Nikolai
16
Jun 21, 2003 08:43 AM
dt4792
Apr 20, 2003 06:48 PM
doodah
Nov 14, 2002 09:13 PM
Haney
Nov 14, 2002 02:29 PM
