new??
Old Aug 28, 2007 | 02:26 PM
cbr900's Avatar
new??
sorry im new to the cummins diesel just bought a 94 2500 manual...the problem is i have to mash the pedal to the floor to get 70 maybe 75 tops on the highway..what can i do to get some more pickup out of it??I just replaced the fuel filter and it didnt change...thanks
Old Aug 28, 2007 | 02:35 PM
dieselman43's Avatar
It all depends on what you want out of your truck and how much you want to spend.
Old Aug 28, 2007 | 03:21 PM
Diesel Dave2's Avatar
Pickin on the wrong admin...
3k springs would help...Also do a check on the throttle linkage and check you shutoff switch(make sure its pulling all the way)...
Old Aug 28, 2007 | 05:54 PM
BigErksG2's Avatar
im with diesel dave on the 3k springs but i would throw in a #6 fuel plate or even take it out. the springs will help you rev more freely and the fuel plate will give you the power to get there. oh and dont forget to turn up the boost.
Old Aug 28, 2007 | 06:01 PM
Box5's Avatar
Grind a 10 or 100 plate, move ur afc and starwheel forward, and do a 3gsk, that will be a good start
Old Aug 28, 2007 | 07:54 PM
wcbcruzer's Avatar
Doesn't sound right. You shouldn't have to floor it to get to 70. Check for boost leaks and fuel pressure. Maybe rear brakes are grabbing?
Old Aug 29, 2007 | 12:10 AM
displacedtexan's Avatar
I agree, trouble shoot what's wrong before you go trying to get more power.
How high can you rev it in neutral? I'd reccomend checking the fuel pressure and boost.
And if you want more power you need gauges. I think they are a good investment on a stock truck for troubleshooting.
Old Aug 29, 2007 | 12:30 AM
BigErksG2's Avatar
i have the auto (doubt it is that much different in high gear) and my truck bone stock would top out at 75mph b/c of all the restrictions on it and wouldnt even maintain speed up a mountain with NO LOAD. did a fuel plate and gauges (gsk is next) and now i can pick up speed on the same mountain without goin anywhere near full throttle.
Old Aug 29, 2007 | 12:48 AM
cbr900's Avatar
thanks for all the help this site is great...guess ill start by tying to find the prob i wasnt sure if it was supposed to be like that or not...this is my first diesel..ill do some more research to get it back to normal then go with the mods u all suggest...how much is the plate and springs gonna run me?also gonna get some gauges,...sorry for all the dumb questions im new to the diesel....thanks
Old Aug 29, 2007 | 01:02 AM
wcbcruzer's Avatar
Free... Gotta love it.
Oh and check out RPMOutlet.com for some gauges. Last time I checked they had some good deals going.
Old Aug 29, 2007 | 06:09 AM
lonewolf42262's Avatar
Whatever you do don't totally remove the fuel plate! Always before modding ensure everything is working as it should. Replace the fuel fiter, ensure no fuel leaks, KDP (do a search and tab it). Inspect the throttle spings, I'd even suggest timing and valve adj. Then mod away, mods always seem to gain alot more when you have a strong base to start with. If your truck is a manual tranny don't expect the stock clutch to hold very much more over stock power range.
Old Aug 29, 2007 | 03:51 PM
dieseldemon's Avatar
What gears do you have in the rear?
Old Aug 29, 2007 | 07:16 PM
cbr900's Avatar
I believe they are still stock gears..I was also told it has a new clutch less then 3 months ago i have the reciept but it dosent say the type of clutch...all i know is that the clutch is real easy to press dosent even feel right compared to my mustang.any one recamend any good manuals or books to buy
Old Aug 29, 2007 | 08:10 PM
wcbcruzer's Avatar
The rear axle comes with either a 3.54 or 4.10 driveshaft to wheel ratio. The Dodge service manual is the best I've heard but my Haynes has served me very well. Stay away from Chilton.
Old Aug 29, 2007 | 08:33 PM
ajs1995's Avatar
my auto floored bone stock would run 95
