New Injectors
New Injectors
I will be installing my new injectors & nozzles tomorrow as soon as the UPS guy gets here. I would like to thank everyone who gave some advice on the questions I've been throwing to you all. You all were a big help.
Now for a question...Do you all have any advice for when I go to install the new injectors? Thanks again!!
Never done a set myself, but there was recently a good post that showed the procedure step by step. I'd give a link, but the search engine hates me. Maybe you'll have better luck.
Fuel Tubes
Should I get new fuel injector tubes(fuel pass through to injector) or just use the stock ones? Also, should I put Never Sieze on anything?
the only time to really replace the connector tubes is if they were mistorqued and tip was damaged from the dealer those tubes are $60 each. no on neverseize
My best advice is to ship them to me. I will learn on the install and I will report back to you when they are in my truck so when you purchase your next set you will have some good instructions from me.
You're funny!!!!! I got some 90 HP nozzles from Dynomite and I found a guy locally who had a set of new injectors. I took the nozzle off one of my old injectors to look at it and there was some black gritty carbon. Is this normal or is it some type of conamination?
contact Shane at PSI Components. He has EDM'd everything from fuel lines, rails and fittings to increase flow to the injectors.
darrenG
06-21-2005 10:24 PM
