New clutch what should i do to the trans?
Old Sep 14, 2007 | 09:12 PM
squirrel's Avatar
My stock clutch with 160,000 miles is slipping pretty bad, i had a hard time passing on the interstate today because of it. Anyways i have done some home work and decided to go with a 500hp Valair 13"clutch. Since i am pulling the trans to replace the clutch is there anything else i should consider doing trans wise wile it is out? I know about the fifth gear nut and intend to take care of that just not sure how yet.
Old Sep 14, 2007 | 10:12 PM
BCB's Avatar
BCB
have you ever had anytrouble with the 5th gear nut? if not it might be a good idea to pull the tail housing and make sure its still tight.
Old Sep 14, 2007 | 11:34 PM
squirrel's Avatar
no 5th gear nut problems yet but i plan on doing the clutch in 2 weeks or so and the plan is to check it then.
Derek Crowl
Aug 20, 2013 10:43 PM
Mattster
Jul 20, 2008 01:55 AM
VikingDiesel
May 1, 2007 01:51 PM
tywebb3
Jun 23, 2006 11:30 PM
